查看: 1633|回复: 0
PT4302-X现货稳定配合
发表于 2011-9-2 15:58:20 | 显示全部楼层 |阅读模式
关键词: PT4302 , PT4302-X
天下粮仓  17:45:41
     PT4302是专为低功耗及高接收感度无线传输控制需求所开发的芯片.
     高整合度的设计,使得PT4302仅需少数几个被动组件配合即可工作,能减少电路板使用面积并缩短开发或样机制作的时间.
     PT4302在设计上特别对功耗作了有效管控,在5V时,315MHz的操作电流少于3mA ,对于日益严格的环保需求或手持式产品提供了良好的解决方案.
     PT4302内建高性能的低噪声放大器(LNA),整合压控震荡器(VCO)和回路滤波器(Loop Filter)的锁相环(PLL)及使用10.7MHz作为其中频,.
     PT4302除省电省零件外,亦具有优异的接收感度和抗噪声能力.特别适合用于汽机车防盗,遥控卷门、灯具、窗帘等环境噪声较大的应用.
     PT4302内建稳压器,可操作在2.4V~5.5V.包装型式则采用好加工的SSOP16小包装。
   PT4302+PT4450目前是行业的选择的黄金担当配合!
    DESCRIPTION
The PT4302 is an ultra-low power OOK/ASK super heterodyne receiver for the 315/434 MHz frequency
bands. It offers a high level of integration and requires only few external components. The PT4302 consists of
a low-noise amplifier (LNA), a down-conversion mixer, an on-chip phase-locked loop (PLL) with integrated
voltage-controlled oscillator (VCO) and loop filter, an OOK/ASK demodulator, a data filter, a data slicing comparator and an on-chip regulator. The PT4302 is available in 16-pin SSOP package and
is specified over the extended temperature range (-40 to +85°C).
    APPLICATIONS
• Automotive Remote Keyless Entry (RKE)
• Remote Control
• Garage door and gate openers
• Suitable for circuit applications that meet either the European ETSI-300-220 or the North American FCC (Part 15) regulatory standards
FEATURES
• Ultra-low power consumption: 2.7 mA for fully operation (315 MHz)
• Few external components
• Excellent Sensitivity of the order of –111 dBm(peak ASK signal level)
• Supply voltage range from 2.4 V to 5.5 V
• 250 MHz to 500 MHz frequency range
• Data rate up to 10 Kb/s
    PTC/普诚科技 旗下还有以下射频芯片:PT4455/PT4301/PT4450/PT4316/PT4317/RX3310A 都可以长期稳定优势供应!
  联系方式Q:42142951 王先生      http://www.natertech.com
