查看: 1136|回复: 0
[供应] PILZ皮尔兹模块773700
发表于 2020-7-27 13:56:05 | 显示全部楼层 |阅读模式
关键词: PILZ皮尔兹
PILZ皮尔兹模块773700
PILZ PNOZ mc1p 773700,可配置安全系统PNOZmulti扩展模块通信接口。
技术细节
证书:        CE, cULus 认证, BG, TüV, KOSHA, CCC
适用于极端环境条件的版本:        标准
宽度尺寸:        45.0 mm
高度尺寸:        94.0 mm
深度尺寸:        121.0 mm
总重:        182 g
净重:        164 g
以摄氏度一表示的环境温度:        0 - 60 °C
PNOZ mc1p
710001    PNOZ c1 24VDC 3n/o 1n/c
710002    PNOZ c2 24VDC 2n/o
720300    PST 4 24 V DC 6S4
720301    PST 4 24 V AC 6S4
720308    PST 4 110 V AC 6S4
720309    PST 4 230 V AC 6S4
750020    PNOZ s connector (10 pieces)
750101    PNOZ s1 24VDC 2 n/o
750102    PNOZ s2 24VDC 3 n/o 1 n/c
750103    PNOZ s3 24VDC 2 n/o
750104    PNOZ s4 24VDC 3 n/o 1 n/c
750105    PNOZ s5 24VDC 2 n/o 2 n/o t
750106    PNOZ s6 24VDC 3 n/o 1 n/c
750107    PNOZ s7 24VDC 4 n/o 1 n/c
750108    PNOZ s8 24VDC 2 n/o
750109    PNOZ s9 24VDC 3 n/o t 1 n/c t
750110    PNOZ s10 24VDC 4 n/o 1 n/c
750111    PNOZ s11 24VDC 8 n/o 1 n/c
750124    PNOZ s4.1 24VDC 3 n/o 1 n/c
750126    PNOZ s6.1 24VDC 3 n/o 1 n/c
750900    PNOZ s pIE
750910    PNOZ s nIE
751500    PNOZ s50 C
751909    PNOZ s9 C (10 pcs.)
772000    PNOZ mm0p 24VDC
772001    PNOZ mm0.1p
772002    PNOZ mm0.2p
772010    PNOZ mm0p-T
772020    PNOZ mml1p
772021    PNOZ mml2p
772030    PNOZ mmc1p ETH
772031    PNOZ mmc2p seriell
772032    PNOZ mmc3p DP
772033    PNOZ mmc4p DN
772034    PNOZ mmc6p CAN
772035    PNOZ mmc7p CC
772036    PNOZ mmc11p CAT
772100    PNOZ m B0
772119    PNOZ m ES Powerlink
772120    PNOZ m EF Multi Link
772121    PNOZ m EF PDP Link
772130    PNOZ m ES ETH
772131    PNOZ m ES RS232
772132    PNOZ m ES Profibus
772134    PNOZ m ES CANopen
772136    PNOZ m ES EtherCAT
772137    PNOZ m ES EtherNet/IP
772140    PNOZ m EF 16DI
772142    PNOZ m EF 8DI4DO
772143    PNOZ m EF 4DI4DOR
772170    PNOZ m EF 1MM
772171    PNOZ m EF 2MM
772200    MM A MINI-IO-CAB01 1.5M
772201    MM A MINI-IO-CAB01 2.5M
772202    MM A MINI-IO-CAB01 5M
773100    PNOZ m1p base unit
773103    PNOZ m1p ETH
773540    PNOZ ml1p safe link
773545    PNOZ ml1p coated version
773600    PDP67 F 8DI ION
773601    PDP67 F 8DI ION HP
773602    PNOZ ml2p safe link PDP
773603    PDP67 F 4 code
773610    PDP67 Connector cs
773612    PDP67 Connector cs VA
773613    PDP67 F 4 code VA
皮尔兹774318
皮尔兹774310
皮尔兹继电器751105 PNOZ s5 C 24VDC 2 n/o 2 n/o t
皮尔兹750104
皮尔兹继电器751330
皮尔兹540030
皮尔兹541103
皮尔兹继电器772100
皮尔兹772142
皮尔兹安全继电器773103
皮尔兹751111
皮尔兹773400
皮尔兹773500
皮尔兹773536
皮尔兹774318
皮尔兹773100
皮尔兹现货  PNOZ X4 230VAC
皮尔兹PNOZ X2.8P 24VACDC 3n/o 1n/c
皮尔兹777301
皮尔兹继电器774500
皮尔兹安全开关540000
皮尔兹继电器750103
皮尔兹继电器750104
皮尔兹继电器750105
皮尔兹继电器750106
皮尔兹继电器750107
皮尔兹继电器750108
皮尔兹继电器750109
皮尔兹安全继电器750103
皮尔兹继电器751111
皮尔兹继电器774080
皮尔兹安全开关570004
皮尔兹继电器774738
皮尔兹安全光栅774310
皮尔兹安全开关541062
皮尔兹安全开关541080
皮尔兹继电器  774330
皮尔兹模块773700
皮尔兹通讯模块773700
皮尔兹通讯模块773500
皮尔兹开关506314
皮尔兹506301
皮尔兹安全光栅787310
皮尔兹控制器773113
皮尔兹安全开关540200
皮尔兹540326
皮尔兹继电器787502
皮尔兹继电器774300
皮尔兹控制器773100
皮尔兹继电器750104
皮尔兹继电器774310
皮尔兹继电器750134
皮尔兹750167
皮尔兹安全光栅541060
皮尔兹533151
皮尔兹继电器777305
皮尔兹继电器751107
皮尔兹继电器774314
皮尔兹继电器751102
皮尔兹继电器751101
皮尔兹继电器750107
皮尔兹继电器751102
皮尔兹继电器751101
皮尔兹继电器750107
皮尔兹继电器774500
皮尔兹继电器777314
皮尔兹继电器774500
皮尔兹继电器777314
皮尔兹开关774130
皮尔兹开关524120
罗斯蒙特浊度仪电极8-0108-0003-iso
罗斯蒙特手操器TREXLFPKLWP3
罗斯蒙特TREXCHPNAWS1S
罗斯蒙特3900-02-10
罗斯蒙特396P-02-10-55
艾默生音叉开关2120D2GV1G5YH0000Q8
艾默生质量流量计1700111ABAEZZZ +F050S114CCAAEZZZZ
E+H PH计CPS11D-7BA21
E+H电导率仪CLD134-PMV538AA1
山武传感器HTY7843D4400
山武传感器HTY7803D4400
欧姆龙
E2E-X2ME1-M3-Z. BY OMS
E2E-X8MB1D8-M3 OMS
CP1E-N60SDR-A   CP1E-N30SDT-D
CP1E-N30SDR-A   CP1E-N40SDT-D
CP1E-N40SDR-A   CP1E-N60SDT-D
CP1H-X40DT-D    CP1H-EX40DT-D
CJ1W-NC413      CJ1W-OD263
NX-OD6121-6     NX-OD6121-5
NX-ID5342       NX-OD5121
NX-PF0730       NX-ECC203
NJ501-1500      NJ501-1300
NJ301-1100      NJ301-1200
NX102-9000      NX102-1000
NX102-1100      NX102-1200
NX1P2-1040DT    NX1P2-1140DT
倍加福KCD2-STC-EX1
倍加福GL5-T/28a/115
倍加福安全栅KCD2-SCD-Ex1
倍加福安全栅KFD2-STC4-Ex1.20
倍加福安全栅KFD2-UFC-Ex1.D
邦纳传感器Q20NFF100
本特利330103-04-09-10-01-CN
萨姆森阀门定位器 4763-01200121000000-0
施迈赛AZS 2305
劳易测ODS 96B M/C6-600-S12
劳易测ODSL 8/C66-45-S12
罗斯蒙特TREXCHPNAWS1
罗斯蒙特2088G4S22A1E5Q4
E+H液位计FTL51-AGR2DB4G4A
山武温控器C35TR1UA2100
山武减压阀KZ03-1B
山武定位器AVP302-WBD2C
劳易测电子报价50129380---HT3C.S/4P
劳易测AMS 304I 120
倍加福NBB2-12GM50-E2-V1
倍加福NCB4-12GM40-N0-10M
本特利177230-01-02-CN
本特利330780-90-00
本特利330180-90-00 现货
本特利330850-90-CN
本特利330103-00-06-10-02-00
本特利330703-000-060-10-02-00
本特利330881-16-11-088-06-02
本特利16925-03
本特利16710-03
邦纳S18SN6D
邦纳MSA-LAT-1
邦纳传感器LTF12IC2LDQ
施迈赛FWS 1206 C
现货萨姆森定位器3725-0000000000.00
贺德克传感器HDA 4840-A-400-424
EDS344-3-016-Y00        ETS 326-3-100-Y00
EDS8446-1-0250-000      HDA 3845-A-250-000
EDS 346-3-400-000       HDA 4445-A-400-Y00
EDS3446-3-0400-Y00      HAD 4445-A-600-000
EDS 345-1-250-000       HAD 4445-A-016-000
EDS346-3-400-000        HAD 4445-A-250-Y00
EDS348-5-016-Y00        HDA4445-A-400-000
EDS 4448-0250-1-PP-000  HDA4745-A-010-000
EDS 4448-0600-1-PP-000  HDA4745-A-400-000
EDS8446-1-0250-000
德国西克激光扫描仪DL100-21HA2103 S30A-6011CA
CLV620-0120    S30A-6111CP
CLV620-1120    S30A-7111CP
CLV621-0120    S30B-3011CA
CLV630-1121S01 S30B-3011DA
CLV630-6120    TIM310-0130000S02
CLV631-0120    TIM310-1030000S02
CLV632-6000    RFH620-1001201
CLV650-0000    TIM510-9950000S01
CLV650-0120    TIM551-2050001
CLV650-6000    TIM571-2050101
倍福模块CP7932-0001-0000   EL1889    EL2889
KL1809  CX1100-0004  EL7211   AX5801-02000
EL2809  CX9020-0115   EL4102  EK1100
EL1809  EL2008  EL6631   ZS1090-0003
EL2904    KL2408    EL7211    BK2020
EL6752   EL8092  EP1008-0001  EL2262
EL1018  EL9410  EL1088  EK1122
EL3102  CX5020-0111  EL6751-0000
EL6751-0000   CX5120-0112/2GB
CX2900-0034  BX3100-0000
CX2100-0004  CX1000-0011
CX5120-0112  EL6731-0000
MTL现货
MTL9491-PS  MTL5541  MTL4511  MTL5575  MTL5511 MTL4546Y  MTL4541  MTL5532  MTL4531  MTL4501-SR  MTL4015  MTL4023  MTL4021  MTL5521
MTL7787P  MTL5521  MTL787S  MTL7028  MTLSD32T3  MTLSD32X   MTLIOP32D
MTLHC32  MTL5544D  MTL4541  MTL4728  MTL5544  MTL5546Y  MTLIOPHC32
MTL5573  MTL5516C  MTL5575  MTL5576  MTL5511  MTL4511  MTL4015  MTL5041
MTL5011B  MTL5074
