PCM1808 MS1808 MS5358 AK5358 AKM5358 AK5357立体声音频AKD5357立体声AKD5358双声道
发布时间:2020-7-4 17:09
发布者:锦宏
8,CS8416,CS8406,CS8422,MS8416瑞盟光纤同轴芯片,笙科A8101/笙科A8102、A9101 9,音频模拟到数字信号TI德州仪器样品151 12476010 莫工 PCM1808 MS1808 MS5358 AK5358 AKM5358 AK5357立体声音频编码器,输出24-Bit, 96-192kHz规格。AK4626 10,AKD5358-B is an evaluation board for the digital audio 24bit 96kHz A/D converter, AK5358. AKD5358-B 11,has analog input circuits and a digital interface transmitter,and can achieve the interface with digital audio 12,systems via opt-connector. 13,AKD5358-B 模拟到数字AKD5357
AK4386 is a 24bit low voltage & low power stereo DAC. The AK4386 uses the Advanced Multi-Bit ΔΣ AK4386ET -20 ~ +85°C 16pin TSSOP (0.65mm pitch) AK4386VT -40 ~ +85°C 16pin TSSOP (0.65mm pitch) AKD4386 Evaluation Board for AK4386 architecture, this architecture achieves DR=100dB at 3V operation. The AK4386 integrates a 2.4GHz音频芯片 |
