keysight(原安捷伦)N8486AQ 40 GHz技术指标
发布时间:2020-6-14 16:07    发布者:zj2572238817
关键词: N8486AQ探头 , 安捷伦N8486AQ , N8486AQ价格
N8486AQ 主要特性与技术指标  keysight(原安捷伦)N8486AQ 40 GHz技术指标  keysight(原安捷伦)N8486AQ 40 GHz技术指标  keysight(原安捷伦)N8486AQ 40 GHz技术指标
东莞市佳华电子仪器有限公司
回收热线:175---6672----8272
销售/维修热线:188---8361---1172
《在线Qq》:25722---38817
邮箱:zyx010414@163.com(可列清单询价/回收)
·EEPROM 可存储校准因数代替手动输入
·宽频率范围:26.5 GHz 至 40 GHz
·宽动态范围:-35 dBm 至 +20 dBm
·小于 1% 的优秀功率线性、失配不确定度的出色驻波比和高度精确的功率可重复性
·精确校准,可追溯至美国国家标准与技术研究所(NIST)
·与 8480 系列兼容的 SCPI 代码(选件 CFT)
Agilent N8486AQ
N8480 Series Power Sensors are the replacement solutions for 8480 Series Power Sensors. The new power sensors are integrated with EEPROM feature, which allows users to calibrate the power sensors without manually entering the calibration factors to the power meter. By comparing to legacy 8480 Series Power Sensors, there are tremendous improvements such as wider dynamic range and frequency range, better accuracy, linearity, repeatability as well as the SWR.
本文地址:https://www.eechina.com/thread-593118-1-1.html     【打印本页】
  • 我们是Microchip
