查看: 897|回复: 0
[供应] 仪器服务商U4941爱德万U4941频谱分析仪
发表于 2020-5-8 20:25:47 | 显示全部楼层 |阅读模式
关键词: U4941频谱分析仪 , 仪器服务商U4941
如若平台没有留有本公司咨询方式,请在浏览器搜索东莞市塘厦佳华电子仪器经营部 欢迎广大朋友前来咨询  上门回收工厂闲置/倒闭电子仪器,个人处理仪器,欢迎您的来电!!
赵经理:188~~~8361~~~1172
企  鹅:25722~~38817
地址:东莞市塘厦镇莲湖怡景路8号爱德万|Advantest U4941 2.2G频谱分析仪 9kHz至2.2GHz
Specifications
Frequency
Frequency range
9kHzto 2.2GHz
Resolution bandwidths
1kHzto 3MHz/outo ,GP(60dB):9/120kHz(not U4941DECT,U4341)
shapefactor
15:1
Frequency span/division
50kHz to 234GHz,zero span
Center frequency accuracy
±5%
Frequency stability
<10kHz,zero opan locdedwith Fref
Resieual FM
<3kHz(V pp)
Referencefrequency drift
±2*10-6/year
Inputlevel
Preamplifier off
+27dBm(ATT10dB)±50V(DC)max.
Preamplifier on
+13dBm±50V(DC)max.
Dynamic range
Inherentnoise
Preamplifier off
(-117+237f/GHz)dBm
(RBW 1kHz,VBW 10Hz,ATT 0dB,frequnecy>1MHz)
Rpeamplifieron
(132+3.3f/GHz)dBm
(RBW 1kHz,VBW 10Hz,ATT dB,frequnecy>1MHz)
Intermodulation distortion
Preamplifieroff:
2nd-order harmonics
≤-70 dB -30dBm input
(ATT0 dB,frequency>10MHz)
3rorder harmonics
≤-70dB,-30dBm inprt
(ATT 0 dB,frequency>10MHz)
Residualresponses
Preamplifier off
≤-100dBm
(ATT 0 dB,inprt terminated with 50Ω frequency>1MHz)
Preamplifieron
≤-115dBm
Pnase noise
-100dBc (Hz) at 20 kHz
Frequency response
±1.0dB(100kHz to 2GHz)
±2.0dB(9kHz to2.2GHz)
(ATT 0 dB,20°C to30°C,ref.to 30MHz and after automatic calibeafion)
Reference level
-64 to +40 dBm (without preamplifier0
Level units
dBm/dBmV/dBV/dBμV/dBpW
Level resolution
10,5,2,1dB
RF attenuator
0to 50dB/10dB
Video filter
10Hz to3MHz
Built-in tracking generator(U4342 only )
Frequency range
100kHz to 2.2GHz
Output level
0 to -30dBm
Sweeptime
4.5ms to 1000s,zero span
U4941
50μsto 1000s,zero apan
Interfaces
IEC625 Bus(IEEE488),RS-232C
