ET2102/ET2104/ET5014电平转换芯片样品技术支持
发布时间:2020-4-11 15:59
发布者:LIJINTAO123
授权代理无锡力芯微电子,电平转换芯片ET2102/ET2104/ET5014 深圳锦宏世纪科技 李工 18938047300 Q:2881671130 ET2102兼容FXMAR2102 ET2102是一款高性能可配置的双向电压双电源转换器。 在广泛的输入和输出电压电平范围内转换。ET2102也可在推挽式中工作。 该设备的设计使得A端口跟踪VCCA级别,B端口跟踪VCCB级别。这允许在1.65V到5.5V的任何两个电平之间进行双向A/B端口电压转换。VCCA可以等于1.65V到5.5V的VCCB。任何一个VCC都可以先通电。如果任何一个VCC被移除,内部断电控制电路将设备置于3状态。 该装置的两个端口具有自动方向感功能。任何一个端口都可以检测到输入信号,并将其作为输出信号传输到另一个端口。 m x 1.4毫米) ET2104替代TXS0104 ET2104是一款高性能可配置的双向电压双电源转换器。在广泛的输入和输出电压电平范围内转换。ET2104还可以在推挽式中工作。环境。它用于I2C总线兼容主设备和从设备之间的电压转换器。提供内部10kΩ上拉电阻。该设备的设计使得A端口跟踪VCCA级别,B端口跟踪VCCB级别。这允许在1.65V到5.5V的任何两个电平之间进行双向A/B端口电压转换。VCCA可以等于1.65V到5.5V的VCCB。任何一个VCC都可以先通电。如果任何一个VCC被移除,内部断电控制电路将设备置于3状态。该装置的四个端口具有自动方向感功能。任何一个端口都可以检测到输入信号,并将其作为输出信号传输到另一个端口。 ET5014替代NLSX5014 The ET5014 is a 4-bit bidirectional level translator in which the input and output ports are switched automatically without direction control. The data path of each channel can be either from I/O_VLn to I/O_VCCn or from I/O_VCCn to I/O_VLn. All of the I/O ports are designed to track two different power supply rails, VCC and VL respectively. Both of the supply voltage are configurable from 1.2V to 4.5V. The VCC and VL supplies are independent which allows a logic signal on the VL side to be translated to either a higher or a lower logic signal voltage on the VCC side, and vice-versa. The ET5014 has high output current capability, which allows the translator to drive high capacitive loads such as most high frequency EMI filters. The enable pin(EN) is used to reduce the power consumption. The EN pin can be used to disable both I/O ports by putting them in 3-state which significantly reduces the supply current from both VCC and VL. The EN signal is referenced to the VL supply. |
