PCB中英对照二
发布时间:2018-10-26 13:51
发布者:JLCS
PCB中英对照二、 基材: 1、 基材:base material 2、 层压板:laminate 3、 覆金属箔基材:metal-clad bade material 4、 覆铜箔层压板:copper-clad laminate (CCL) 5、 单面覆铜箔层压板:single-sided copper-clad laminate 6、 双面覆铜箔层压板:double-sided copper-clad laminate 7、 复合层压板:composite laminate 8、 薄层压板:thin laminate 9、 金属芯覆铜箔层压板:metal core copper-clad laminate 10、 金属基覆铜层压板:metal base copper-clad laminate 11、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film 12、 基体材料:basis material 13、 预浸材料:prepreg 14、 粘结片:bonding sheet 15、 预浸粘结片:preimpregnated bonding sheer 16、 环氧玻璃基板:epoxy glass substrate 17、 加成法用层压板:laminate for additive process 18、 预制内层覆箔板:mass lamination panel 19、 内层芯板:core material 20、 催化板材:catalyzed board ,coated catalyzed laminate 21、 涂胶催化层压板:adhesive-coated catalyzed laminate 22、 涂胶无催层压板:adhesive-coated uncatalyzed laminate 23、 粘结层:bonding layer 24、 粘结膜:film adhesive 25、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film 26、 无支撑胶粘剂膜:unsupported adhesive film 27、 覆盖层:cover layer (cover lay) 28、 增强板材:stiffener material 29、 铜箔面:copper-clad surface 30、 去铜箔面:foil removal surface 31、 层压板面:unclad laminate surface 32、 基膜面:base film surface 33、 胶粘剂面:adhesive faec 34、 原始光洁面:plate finish 35、 粗面:matt finish 36、 纵向:length wise direction 37、 模向:cross wise direction 38、 剪切板:cut to size panel 39、 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL) 40、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL) 41、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates 42、 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates 43、 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates 44、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates 45、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates 46、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates 47、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates 48、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates 49、 超薄型层压板:ultra thin laminate 50、 陶瓷基覆铜箔板:ceramics base copper-clad laminates 51、 紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates TEL 18681567708 详情可见www.sz-jlc.com/s |
