MAXM17505高效DC-DC降压型电源模块
发布时间:2015-7-6 14:44    发布者:eechina
关键词: MAXM17505 , DC-DC , 降压型电源
Maxim MAXM17505 High-Efficiency DC-DC Step-Down Power Modules integrates a number of devices in a low-profile, thermally efficient system-in-package (SiP). They combine a switching power supply controller, dual n-channel MOSFET power switches, fully-shielded inductor, and the compensation components all in a single package. Each of these devices operate over a wide input voltage range of 4.5V to 60V and delivers up to 1.7A continuous output current. This provides an excellent line and load regulation over an output voltage range of 0.9V to 12V. The device only requires five external components to complete the total power solution. The high level of integration significantly reduces design complexity, manufacturing risks, and offers a true plug-and-play power supply solution.
View Product List
Features
Reduces Design Complexity, Manufacturing Risks, and Time-to-Market
Integrated Switching Power Supply Controller and Dual-MOSFET Power Switches
Integrated Inductor
Integrated Compensation Components
Integrated Thermal-Fault Protection
Integrated Peak Current Limit
Saves Board Space in Space-Constrained Applications
Complete Integrated Step-Down Power Supply in a Single Package
Small Profile 9mm x 15mm x 2.8mm SiP Package
Simplified PCB Design with Minimal External BOM Components
Offers Flexibility for Power-Design Optimization
Wide Input Voltage Range from 4.5V to 60V
Output-Voltage Adjustable Range from 0.9V to 12V
Adjustable Frequency with External Frequency Synchronization (100kHz to 1.8MHz)
Soft-Start Programmable
Autoswitch PWM, PFM, or DCM Current-Mode Control
Optional Programmable EN/UVLO
Applications
Distributed Supply Regulation
FPGA and DSP Point-of-Load Regulator
HVAC and Building Control
Industrial Power Supplies
Typical Application Circuit
本文地址:https://www.eechina.com/thread-151168-1-1.html     【打印本页】
