查看: 4150|回复: 0
GMS81C2020单片机解密
发表于 2010-4-21 15:43:31 | 显示全部楼层 |阅读模式
关键词: 单片机 , 解密
GMS81C2020单片机解密/芯片解密以及其他众多LG(HYUNDAI)系列芯片解密是芯谷芯片解密事业部近期以来取得重大技术进展的典型优势解密项目之一,目前,针对LG(HYUNDAI)系列GMS单片机及HMS芯片,我们均已经拥有较为成熟可靠的优质解密方案。
欲了解更多GMS81C2020单片机解密/芯片解密详情,请与芯谷芯片解密事业部联系
以下是我们仅针对GMS81C2020单片机的主要性能特征进行分析介绍,供广大客户参考借鉴。
 The GMS81C2020 and GMS81C2120 are an advanced CMOS 8-bit microcontroller with 20K/12K bytes of ROM. These are a powerful microcontroller which provides a highly flexible and cost effective solution to many VFD applications. These provide the following standard features: 20K/12K bytes of ROM, 448 bytes of RAM, 8-bit timer/counter, 8-bit A/D converter, 10-bit High Speed PWM Output, Programmable Buzzer Driving Port, 8-bit Basic Interval Timer, 7-bit Watch dog Timer,8-bit, Serial Peripheral Interface, on-chip oscillator and clock circuitry. They also come with high voltage I/O pins that can directly drive a VFD(Vacuum Fluorescent Display). In addition, the GMS81C2020 and GMS81C2120 support power saving modes to reduce power consumption.
  Features
  20K/12K bytes ROM(EPROM)
  448 Bytes of On-Chip Data RAM
  (Including STACK Area)
  Minimum Instruction Execution time :
  - 1uS at 4MHz ( 2cycle NOP Instruction )
  One 8-Bit Basic Interval Timer
  One 7-Bit Watch Dog Timer
  Two 8-Bit Timer/Counters
  10-Bit High Speed PWM Output
  One 8-bit Serial Peripheral Interface
  Two external interrupt ports
  One Programmable 6-Bit Buzzer Driving port
  60 I/O Lines
  - 56 Programmable I/O pins :
  30 high-voltage pins (40V,max)
  - 3 Input Only pins : 1 high-voltage pin
  - 1 Output Only pin
  Eight Interrupt Sources
  - 2 By External Sources (INT0, INT1)
  - 2 By Timer/Counter Sources (Timer0, Timer1)
  - 4 By Functional Sources (SPI,ADC,WDT,BIT)
  12-Channel 8-Bit On-Chip Analog to Digital Converter
  Oscillatior :
  - Crystal
  - Ceramic Resonator
  - External RC Oscillator
  - Internal RCWDT Oscillatior
  Low Power Dissipation Modes
  - STOP mode
  - Wake-up Timer Mode
  - Standby Mode
  - Watch Mode
  - Subactive Mode
  Operating Voltage : 4.0V ~ 5.5V (at 4.5MHz)
  Operating Frequency : 0.4MHz ~ 4.5MHz
  Subclock : 32.768KHz Crystal Oscillator
  Enhanced EMS Improvement
  Power Fail Processor
  ( Noise Immunity Circuit )
文章来源http://www.szxpjm.com/ic/GMS81C2020dpjjm__xg_114.html
