查看: 991|回复: 0
MUN2230T1解密
发表于 2012-11-12 11:56:58 | 显示全部楼层 |阅读模式
近期以来,鑫锐专业的芯片解密技术攻关团队在MUN2230T1解密领域取得突破,经过多次反复实验和实际解密过程的验证,我们目前可以为客户提供系列单片机高效可靠的解密方案。以下信息是此解密芯片技术特性简介:
  This new series of digital transistors is designed to replace a single device and its external resistor bias network. The BRT (Bias Resistor Transistor) contains a single transistor with a monolithic bias network consisting of two resistors; a series base resistor and a base–emitter resistor. The BRT eliminates these individual components by integrating them into a single device. The use of a BRT can reduce both system cost and board space. The device is housed in the SC–59 package which is designed for low power surface mount applications.
  ·Simplifies Circuit Design
  ·Reduces Board Space
  ·Reduces Component Count
  ·The SC–59 package can be soldered using wave or reflow.
  ·Available in 8 mm embossed tape and reel Use the Device Number  to order the 7 inch/3000 unit reel.
  有MUN2230T1芯片解密需求者请直接与鑫锐科技联系咨询更多解密详情http://www.dpjjm.com
