Qualcomm QCN9024 MX6924 F5 4x4 MIMO 802.11ax WiFi6 Module
2023年02月10日 14:46 发布者:maxon2023
Description
MX6924 F5 802.11ax Embedded Wireless modules is an embedded wireless module that adopts M.2 E-key and supports PCI Express 3.0 protocol.
It adopts Qualcomm® 802.11ax Wi-Fi technology, supports the 5180-5850GHz frequency band, has AP and STA functions with 4x4 MIMO and 4 spatial streams, suitable for applications of 5GHz IEEE802.11a/n/ac/ax.
It is equipped with a dynamic frequency selection (DFS) function which has higher transmission efficiency than the previous.
Specifications
Type: Wireless Module
Chip: QCN9024
IEEE Standard: IEEE 802.11ax
Connector: PCI Express 3.0, M.2 E-key
Working voltage: 3.3V
Frequency range: 5180~5320GHz 5745~5825GHz
Modulation technology: 802.11n: OFDM (BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM) ;802.11ac: OFDM (BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM) ; 802.11ax: OFDMA (BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM)
power (per chain): 802.11ax: Max. 24dBm
Power consumption: ≦15W
Receiving Sensitivity: 11ax:HE20 MCS0 <-95dBm / MCS11 <-62dBm;HE40 MCS0 <-89dBm / MCS11 <-60dBm;HE80 MCS0 <-86dBm / MCS11 <-56dBm;HE160 MCS0 <-87dBm / MCS9 <-64dBm
Antenna Connector: 4 x U. FL
Operating Environment: Temperature: -20°C to 70°C/-4 ~ 158℉; Humidity: 95% (non-condensing)
Storage Environment: Temperature: -40°C to 90°C/-40 ~ 194℉; Humidity: 90% (non-condensing)
Certification: RoHS/REACH
Weight: 18g
Dimensions (W*H*D): 55.9 x 52.8x 8.5 mm (±0.1mm)
