Freescale QorIQ P1025 Tower MPU模块开发方案
发布时间:2012-9-5 11:19
发布者:1770309616
Freescale公司的QorIQ P1025通信处理器采用Power架构e500内核,32 KB L1 高速缓存,工作弊频率高达667 MHz,支持ECC的32位DDR2/DDR3 SDRAM存储器控制器,带ECC的246KB L2缓存,两个10/100/1000Mbps增强三速以太网控制器(eTSEC),主要用在工业机器人,智能电网和智能电表,网络,以太网交换,多服务商业网关,WLAN接入点和固定路由器.本文介绍了QorIQ P1016和P1025主要特性,QorIQ P1016和P1025方框图,TWR-P1025 Tower MPU模块主要特性,框图和完整电路图. The QorIQ P1 platform series, which includes the P1016 and P1025 communications processors, offers extensive integration and extreme power for a wide variety of applications in the networking, telecom, defense and industrial markets. Based on 45 nm technology for low-power implementation, the P1016 and P1025 processors provide single- and dual-core solutions for the 400 MHz to 667 MHz performance range, along with advanced security, QUICC Engine for multiprotocol support and a rich set of interfaces. The QorIQ P1016 and P1025 processors are pin-compatible with the QorIQ P1015, P1024 products, and software compatible with the P1011/P1020 and P2010/P2020 offering a six-chip range of cost-effective solutions. Scaling from a single core at 400 MHz (P1015) to a dual core at 1.2 GHz per core (P2020), the two QorIQ platforms deliver an impressive 4.5x aggregate frequency range. QorIQ P1025主要特性: Dual (P1025) or single (P1016) high-performance Power Architecture® e500 cores, 32 KB L1 cache, up to 667 MHz 32-bit DDR2/DDR3 SDRAM memory controller with ECC support 256 KB L2 cache with ECC. Also configurable as SRAM and stashing memory Two 10/100/1000 Mbps enhanced three-speed Ethernet controllers (eTSECs) QUICC Engine module supporting UTOPIA-L2, four T1/E1/HDLC and two 10/100 Ethernet interfaces High-speed interfaces supporting various multiplexing options: Four SerDes up to 3.125 GHz multiplexed across controllers Two PCI Express® interfaces Two SGMII interfaces Dual high-speed USB controllers (USB 2.0) Integrated security engine Protocol support includes SNOW, ARC4, 3DES, AES, RSA/ECC, RNG, single-pass SSL/TLS, Kasumi, XOR acceleration eLBC, TDM, eSDHC, Dual I2C, DUART, PIC, DMA, GPIO Package: 561-pin temperature-enhanced plastic BGA (TEPBGA1) 0C to 125C Tj -40C to 125C Tj option QorIQ P1025目标应用: Industrial Industrial Robot Smart Grid and Smart Metering Networking Ethernet Switch Multi-Service Business Gateway Wireless LAN Access Point Fixed Routers 图1.QorIQ P1016和P1025方框图 TWR-P1025 Tower MPU模块 The TWR-P1025 is a Tower Controller Module compatible with the Freescale Tower System. It can function as a stand-alone, low-cost platform for the evaluation of the QorIQ P1xxx family of microprocessor (MPU) devices. The TWR-P1025 features the QorIQ P1025 dual core processor based on the PowerPC® e500 core architecture. The TWR-P1025 is available as a stand-alone product or can be combined with the Tower Elevator Modules (TWR-ELEV) and other Tower eco-system components to create development platforms for a ide variety of applications. TWR-P1025 Tower MPU模块主要特性: The features of the TWR-P1025 Tower MPU Module: • Tower compatible microprocessor module • Dual core P1025 in a 561 TEPBGA package operating up to 533 MHz • P1025 JTAG • CPLD JTAG • Three axis accelerometer (MMA8451Q) • Two (2) user-controllable LEDs • One (1) reset pushbutton switch • Ten-way DIP Switch for configuration • microSD card slot • mini-PCIe slot • Two (2) 10/100/1000Mbps Ethernet RJ45 • Two (2) USB2.0 Type A • One (1) mini-USB TypeB dual UART • 512 MB DDR3@667 MHz • 64 MB Flash • IEEE1588 pinned to header + DAC and VXCO (DNP option) 图2.TWR-P1025 Tower MPU模块外形图 图3.TWR-P1025 Tower MPU模块框图 图4.TWR-P1025 Tower MPU模块电路图(1) 图5.TWR-P1025 Tower MPU模块电路图(2) 图6.TWR-P1025 Tower MPU模块电路图(3) 图7.TWR-P1025 Tower MPU模块电路图(4) 图8.TWR-P1025 Tower MPU模块电路图(5) 图9.TWR-P1025 Tower MPU模块电路图(6) 图10.TWR-P1025 Tower MPU模块电路图(7) 图11.TWR-P1025 Tower MPU模块电路图(8) 图12.TWR-P1025 Tower MPU模块电路图(9) 图13.TWR-P1025 Tower MPU模块电路图(10) 图14.TWR-P1025 Tower MPU模块电路图(11) 图15.TWR-P1025 Tower MPU模块电路图(12) 图16.TWR-P1025 Tower MPU模块电路图(13) 图17.TWR-P1025 Tower MPU模块电路图(14) 详情请见: 和 来源:网络 |
