AKM AK4688立体声音频CODEC解决方案
发布时间:2012-8-28 13:46
发布者:1770309616
AKM公司的AK4688是立体声音频CODEC,集成了具有24位输入/输出数据的ADC和DAC接口,支持异步操作.64x过取样,取样速率高达48kHz,线性相位数字抗混淆滤波器,S/(N+D)为83dB,动态范围105dB,S/N为99dB, 3.3V单电源输出达2Vrms,适合用于数字录音系统,DTV,蓝光记录仪和家庭影院.本文介绍了AK4688主要特性,方框图,典型应用电路以及评估板AKD4688-A主要功能,方框图,电路图和PCB元件布局图. The AK4688 is a stereo audio CODEC. The integrated ADC and DAC interfaces accept up to 24-bit input/output data and support an asynchronous operation. The input range of the pre-amplifier, that supports line inputs, is adjustable by an external resistor. A ground referenced 2Vrms output with a 3.3V single power supply is achieved by an integrated charge pump, reducing external parts such as AC-coupling capacitors and mute circuits. The ADC block of the AK4688 achieves a dynamic range of 99dB, and the DAC block achieves a dynamic range of 105dB. The AK4688 is suitable for digital recording systems, digital TVs, Blu-ray recorders and Home theater systems. AK4688主要特性: Asynchronous ADC/DAC Operation Capless Stereo Pre-amplifier for Line Input/Output 24bit Stereo ADC - 64x Oversampling - Sampling Rate up to 48kHz - Linear Phase Digital Anti-Alias Filter - S/(N+D): 83dB - Dynamic Range, S/N: 99dB - Digital HPF for Offset Cancellation 24bit Stereo DAC - 128x Oversampling - Sampling Rate up to 192kHz - 24bit 8 times Digital Filter - S/(N+D): 95dB - Dynamic Range, S/N: 105dB - De-emphasis Filter High Jitter Tolerance External Master Clock Input: 256fs, 384fs, 512fs 768fs (fs=32kHz ∼ 48kHz) 128fs, 192fs, 256fs 384fs (fs=64kHz ∼ 96kHz) 128fs, 192fs (fs=128kHz ~ 192kHz) 2 Audio Serial I/F (PORT1, PORT2) - Master/Slave mode (PORT1) - I/F format PORT1, 2: MSB, LSB justified (16/24 bit), I2S Hardware / I2C-bus Control Operating Voltage: - Digital I/O and Charge Pump: 3.0V ∼ 3.6V - ADC Analog: 3.0V ∼ 3.6V - DAC Analog: 3.0V ∼ 3.6V Package: 36pin QFN 图1.AK4688方框图 图2.AK4688典型应用框图(I2C控制模式, CAD0 引脚= “L”, 主模式) 图3.AK4688典型应用框图(H/W控制模式, MCLK=768fs, 主模式) 评估板AKD4688-A AKD4688-A is an evaluation board for AK4688, which is a single chip 24bit CODEC with a 2ch ADC and a 2ch DAC. It is possible to evaluate not only A/D and D/A of the AK4688, but also asynchronous operation characteristics. Also, the board could be connected to a digital’s audio equipment easily with S/PDIF connectors. 评估板AKD4688-A功能: Compatible with 2 types of digital audio interface - Optical (S/PDIF) input/output with DIT/DIR (AK4118A) - 10pin headers for interfacing with external data source Separate power supply or regulator power supply 10pin header for register control 图4.评估板AKD4688-A框图 图5.评估板AKD4688-A电路图(1) 图6.评估板AKD4688-A电路图(2) 图7.评估板AKD4688-A电路图(3) 图8.评估板AKD4688-A电路图(4) 图9.评估板AKD4688-A电路图(5) 图10.评估板AKD4688-A电路图(6) 图11.评估板AKD4688-A PCB元件布局图(顶层) 图12.评估板AKD4688-A PCB元件布局图(底层) 详情请见: 和 来源:网络 |
