Powerint TOP270VG 100W小型反激电源解决方案
发布时间:2012-8-24 16:14
发布者:1770309616
Powerint公司的TOPSwitch-JX系列产品集成了725V功率MOSFET,高压开关电流源,多模式PWM控制器,振荡器,热关断电路,故障保护和其它控制电路,适合用于10W-245W的电源.265VAC时无负载的功耗小于100mW,主要用在笔记本电脑适配器,打印机,LCD监视器,STB,PC或LCD TV待机电源,音频放大器.本文介绍了TOPSwitch-JX系列产品亮点,方框图, 19V 65W反激电源电路图和12V 30W反激电源电路图以及12V/24V 100W反激电源评估板主要特性和指标,电路图,变压器电路图与材料清单,PCB布局图. TOPSwitch-JX cost effectively incorporates a 725 V power MOSFET, high-voltage switched current source, multi-mode PWM control, oscillator, thermal shutdown circuit, fault protection and other control circuitry onto a monolithic device. TOPSwitch-JX系列产品亮点: EcoSmart – Energy Effi cient • Ideal for applications from 10 W to 245 W • Energy efficient over entire load range • No-load consumption below 100 mW at 265 VAC • Up to 750 mW standby output power for 1 W input at 230 VAC High Design Flexibility for Low System Cost • Multi-mode PWM control maximizes effi ciency at all loads • 132 kHz operation reduces transformer and power supply size • 66 kHz option for highest effi ciency requirements • Accurate programmable current limit • Optimized line feed-forward for line ripple rejection • Frequency jittering reduces EMI fi lter cost • Fully integrated soft-start for minimum start-up stress • 725 V rated MOSFET • Simplifi es meeting design derating requirements Extensive Protection Features • Auto-restart limits power delivery to <3% during overload faults • Output short-circuit protection (SCP) • Output over-current protection (OCP) • Output overload protection (OPP) • Output overvoltage protection (OVP) • User programmable for hysteretic/latching shutdown • Simple fast AC reset • Primary or secondary sensed • Line undervoltage (UV) detection prevents turn-off glitches • Line overvoltage (OV) shutdown extends line surge withstand • Accurate thermal shutdown with large hysteresis (OTP) Advanced Package Options • eDIP™-12 package: • 43 W / 117 W universal input power output capability with PCB / metal heat sink • Low profi le horizontal orientation for ultra-slim designs • Heat transfer to both PCB and heat sink • Optional external heat sink provides thermal impedance equivalent to a TO-220 • eSIP™-7C package: • 177 W universal input output power capability • Vertical orientation for minimum PCB footprint • Simple heat sink mounting using clip provides thermal impedance equivalent to a TO-220 • eSOP™-12 package: • 66 W universal input output power capability • Low profi le surface mounted for ultra-slim designs • Heat transfer to PCB via exposed pad and SOURCE pins • Supports wave or refl ow soldering • Extended creepage to DRAIN pin • Heat sink is connected to SOURCE for low EMI TOPSwitch-JX系列典型应用: • Notebook or laptop adapter • Generic adapter • Printer • LCD monitor • Set-top box • PC or LCD TV standby • Audio amplifi er 图1.TOPSwitch-JX系列方框图 图2.TOPSwitch-JX系列通用输入19V 65W反激电源电路图 图3.TOPSwitch-JX系列通用输入12V 30W反激电源电路图 12V/24V 100W反激电源评估板 This document is an engineering report describing a 12 V / 24 V, 100 W flyback DC-DC converter utilizing a TOP270VG from the TOPSwitch-JX family of ICs. This power supply is intended for use in an LCD TV with LED back light. The board requires +380 VDC input, supplied from the PFC stage in a typical TV design. 100W反激电源评估板主要特性: Highly energy efficient Full load efficiency >90% Efficiency >89% above 10% load Average efficiency >90% (25%, 50%, 75%, 100% load points) Simplifies meeting ENERGY STAR 2.0 and EuP requirements Low cost, low component count and small PCB footprint solution Performance met without synchronous output rectification 132 kHz operation optimized core size and efficiency performance Low profile eDIP™-12 package for ultra-slim designs Integrated protection and reliability features Line under voltage lock out (UVLO) Primary sensed output overvoltage shutdown (OVP). Latched OVP condition can be reset with a fast AC reset circuit. Auto recovery output over current (OCP) Meets limited power source (LPS) <100 VA requirement with a single point of failure Accurate thermal shutdown with large hysteresis 图4.100W反激电源评估板外形图 100W反激电源主要指标: 图5.100W反激电源评估板电路图 100W反激电源评估板材料清单(BOM): 图6.100W反激电源评估板PCB布局图(顶层) 图7.100W反激电源评估板PCB布局图(底层) 图8.变压器电路图 详情请见: 来源:网络 |
