89C51编程程序
- #include "at89x52.h"
- #include "stdio.h"
- #include "intrins.h"
- #include "ctype.h"
- sbit rdy=P3^2;
- sbit vpp=P3^3;
- sbit p26=P3^4;
- sbit p27=P3^5;
- sbit p36=P3^6;
- sbit p37=P3^7;
- sbit prog=P2^7;
- void init_serial()
- SCON=0x50; /*mode 1*/
- TMOD=0x20;
- TH1=0xfd;
- PCON=0x80; /*38400bps*/
- TR1=1; /*load tmr1*/
- TI=1;
- ES=1;}
- void init_pro()
- p26=0;
- p27=0;
- p36=0;
- p37=0;
- vpp=1;
- prog=1;
- void sendbyte(unsigned char da) /*send a byte*/
- while(!TI);
- TI=0;
- SBUF=da;}
- unsigned char IntToAscii(unsigned char a) /*change DEC to ASCII HEX code*/
- if(a<10) return a+48;
- if(a>9) return a+55;}
- unsigned int getadr() /*get 5 diti DEC adr*/
- unsigned char i,a[5];
- for(i=0;i<5;i++)
- while(!RI);
- RI=0;
- a=SBUF-48;
- return a[0]*10000+a[1]*1000+a[2]*100+a[3]*10+a[4];}
- unsigned char getdata() /*get 2 diti HEX data*/
- unsigned char d1,d2;
- while(!RI);
- RI=0;
- d1=toint(SBUF);
- while(!RI);
- RI=0;
- d2=toint(SBUF);
- return d1*16+d2;}
- unsigned int detchip(int adr)
- P0=0xff;
- P1=adr%256;P2=adr/256;
- init_pro();
- _nop_();_nop_();_nop_();_nop_();_nop_(); /*delay 10 us*/
- return P0;}
- void read()
- unsigned int adr,maxadr;
- unsigned char h,l;
- P0=0xff;
- maxadr=getadr();
- for(adr=0;adr
- p26=0;
- p27=0;
- p36=1;
- p37=1;
- vpp=1;
- prog=1;
- h=IntToAscii(P0/16);
- sendbyte(h);
- l=IntToAscii(P0%16);
- sendbyte(l);}
- init_pro();}
- unsigned int test(unsigned int nn)
- unsigned int adr,counter=0;
- P0=0xff;
- for(adr=0;adr
- p26=0;
- p27=0;
- p36=1;
- p37=1;
- vpp=1;
- prog=1;
- if(P0!=0xff) counter++;}
- init_pro();
- return counter;}
- unsigned char erase(unsigned int nn,unsigned int p)
- unsigned int i;
- P0=0xff;
- p26=1;
- p27=0;
- p36=0;
- p37=0;
- vpp=0;
- prog=1;
- for(i=0;i<50000;i++) _nop_();
- switch(p)
- case 0 : prog=0;
- prog=1;
- break;
- case 1 : prog=0;
- _nop_();
- prog=1;
- break;
- case 2 : prog=0;
- _nop_();_nop_();
- prog=1;
- break;
- case 3 : prog=0;
- prog=1;
- break;
- case 4 : prog=0;
- prog=1;
- break;
- case 5 : prog=0;
- prog=1;
- break;
- case 6 : prog=0;
- _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
- prog=1;
- break;
- case 7 : prog=0;
- _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
- prog=1;
- break;
- case 8 : prog=0;
- _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
- prog=1;
- break;
- default: prog=0;
- for(i=0;i
- prog=1;
- break;}
- vpp=1;
- for(i=0;i
- if(test(nn)==0) return 's';
- else return 'f';}
- unsigned char write()
- unsigned int adr,d,i;
- p26=0;
- p27=1;
- p36=1;
- p37=1;
- vpp=0;
- prog=1;
- for(i=0;i<4000;i++) _nop_();
- adr=getadr();
- d=getdata();
- while(1)
- if(adr>50000) break;
- P1=adr%256;P2=(adr/256)|0x80;
- P0=d;
- TI=0;
- SBUF='s';
- prog=0;
- prog=1;
- adr=getadr();
- d=getdata();
- while(!rdy);}
- init_pro();
- return 'f';}
- unsigned char lock(unsigned char level)
- unsigned int i;
- vpp=0;
- if(level==1) {p26=1;p27=1;p36=1;p37=1;}
- if(level==2) {p26=1;p27=1;p36=0;p37=0;}
- if(level==3) {p26=1;p27=0;p36=1;p37=0;}
- prog=1;
- prog=0;
- prog=1;
- while(!rdy);
- init_pro();
- return 'o';}
- void main()
- unsigned char data c;
- unsigned int data adr,l,dx;
- init_pro();
- init_serial();
- while(1)
- init_pro();
- scanf("%c",&c);
- switch(c)
- case 'c' : printf("%c",'o');
- break;
- case 'd' : scanf("%x",&adr);
- printf("%x",detchip(adr));
- break;
- case 't' : scanf("%u",&dx);
- printf("%u",test(dx));
- break;
- case 'r' : read();
- break;
- case 'e' : scanf("%u,%u",&adr,&dx);
- printf("%c",erase(adr,dx));
- break;
- case 'w' : printf("%c",write());
- break;
- case 'l' : scanf("%u",&l);
- printf("%c",lock(l));
- break;
- case 'h' : printf("**********Er6y Programmer Help Window***********\n");
- break;
- default : break;}
复制代码
文章来源:http://www.originic.hk/bbs/display.asp?id=290
