ADI ADMP441高性能低功耗数字MEMS麦克风解决方案
发布时间:2012-7-18 10:54
发布者:1770309616
ADI公司的ADMP441是高性能低功耗数字输出全方位的MEMS麦克风,包括有MEMS传感器,信号调理,ADC,抗混淆滤波器,电源管理以及工业标准的24位I2S接口,并直接连到数字处理器如DSP和MCU.SNR为61 BA,灵敏度为−26 dBFS,平坦的频率响应60Hz到15kHz,主要用在远程会议,游戏控制台,移动设备,笔记本电脑,平板电脑和安全系统.本文介绍了ADMP4411主要特性,方框图,系统框图和评估板子板EVAL-ADMP441Z电路图,材料清单. The ADMP4411 is a high performance, low power, digital output, omnidirectional MEMS microphone with a bottom port. The complete ADMP441 solution consists of a MEMS sensor, signal conditioning, an analog-to-digital converter, antialiasing filters, power management, and an industry standard 24-bit I2S interface. The I2S interface allows the ADMP441 to connect directly to digital processors, such as DSPs and microcontrollers, with-out the need for an audio codec in the system. The ADMP441 has a high SNR and high sensitivity, making it an excellent choice for far field applications. The ADMP441 has a flat wideband frequency response, resulting in natural sound with high intelligibility. A built-in particle filter provides high reliability. The ADMP441 is available in a thin 4.72 mm × 3.76 mm × 1 mm surface-mount package. It is reflow solder compatible with no sensitivity degradation. The ADMP441 is halide free. ADMP4411主要特性: Digital I²S interface with high precision 24-bit data High SNR of 61 dBA High sensitivity of −26 dBFS Flat frequency response from 60 Hz to 15 kHz Low current consumption of 1.4 mA High PSR of −75 dBFS Small 4.72 mm × 3.76 mm × 1 mm surface-mount package Compatible with Sn/Pb and Pb-free solder processes RoHS/WEEE compliant ADMP4411应用: Teleconferencing systems Gaming consoles Mobile devices Laptops Tablets Security systems 图1.ADMP4411功能框图 图2.ADMP4411系统框图 评估板子板EVAL-ADMP441Z EVAL-ADMP441Z SDP Daughter Board for the ADMP441 I2S MEMS Microphone The EVAL-ADMP441Z is an evaluation board that works with the EVAL-ADMP441Z-FLEX and the system demonstration platform (SDP) to allow quick evaluation of the performance of the ADMP441 MEMS microphone. This evaluation system can be used to stream two channels of audio from two ADMP441 microphones to a PC over a USB connection. The system identifies itself to a PC as a standard USB audio interface; therefore, no additional drivers or software are required to run the system. One EVAL-ADMP441Z-FLEX board is included in the evaluation kit. The SDP-B controller board is purchased separately. The EVAL-ADMP441Z board also provides hardware control and probe/test points to examine the digital signals of the ADMP441. 评估套件包括: EVAL-ADMP441Z daughter board EVAL-ADMP441Z-FLEX board 5 V power supply 图3.评估板子板EVAL-ADMP441Z外形图 图4.评估板子板EVAL-ADMP441Z电路图 评估板子板EVAL-ADMP441Z材料清单: 详情请见: 和 来源:网络 |
