Cypress CY7C68053 USB 2.0 MCU开发方案
发布时间:2012-7-12 20:15
发布者:1770309616
Cypress公司的MoBL-USB™ FX2LP18 (CY7C68053)是低功耗高度集成的USB 2.0 微控制器(MCU),集成了USB 2.0收发器,串行接口引擎(SIE),增强型8051微控制器和可编程外设接口,超低功耗.数据速率超过53MB/秒,达到USB 2.0带宽最大允许值,主要用在手机,智能手机,PDA,MP3播放器等.本文介绍了CY7C68053主要特性,方框图以及CY3687 MoBL-USB FX2LP18开发板主要特性,电路图,材料清单和PCB布局图. Cypress Semiconductor Corporation’s MoBL-USB™ FX2LP18 (CY7C68053) is a low voltage (1.8 V) version of the EZ-USB® FX2LP (CY7C68013A), which is a highly integrated, low power USB 2.0 microcontroller. By integrating the USB 2.0 transceiver, serial interface engine (SIE), enhanced 8051 microcontroller, and a programmable peripheral interface in a single chip, Cypress has created a very cost effective solution that provides superior time-to-market advantages with low power to enable bus powered applications. The ingenious architecture of MoBL-USB FX2LP18 results in data transfer rates of over 53 Mbytes per second, the maximum allowable USB 2.0 bandwidth, while still using a low cost 8051 microcontroller in a package as small as a 56VFBGA (5 mm x 5 mm). Because it incorporates the USB 2.0 transceiver, the MoBL-USB FX2LP18 is more economical, providing a smaller footprint solution than USB 2.0 SIE or external transceiver implementations. With MoBL-USB FX2LP18, the Cypress Smart SIE handles most of the USB 1.1 and 2.0 protocol in hardware, freeing the embedded microcontroller for application-specific functions and decreasing development time to ensure USB compatibility. The General Programmable Interface (GPIF) and Master/Slave Endpoint FIFO (8 or 16-bit data bus) provide an easy and glueless interface to popular interfaces such as ATA, UTOPIA, EPP, PCMCIA, and most DSP/processors. CY7C68053主要特性: ■ USB 2.0 9 V USB-IF high speed and full speed compliant (TID#40000188) ■ Single-chip integrated USB 2.0 transceiver, smart SIE, and enhanced 8051 microprocessor ■ Ideal for mobile applications (cell phone, smart phones, PDAs, MP3 players) ❐ Ultra low power ❐ Suspend current: 20 μA (typical) ■ Software: 8051 Code runs from: ❐ Internal RAM, which is loaded from EEPROM ■ 16 kBytes of on-chip code/data RAM ■ Four programmable BULK/INTERRUPT/ISOCHRONOUS endpoints ❐ Buffering options: double, triple, and quad ■ Additional Programmable (BULK/INTERRUPT) 64-Byte Endpoint ■ 8 or 16-Bit External Data Interface ■ Smart Media Standard ECC Generation ■ GPIF (General Programmable Interface) ❐ Allows direct connection to most parallel interface ❐ Programmable waveform descriptors and configuration registers to define waveforms ❐ Supports multiple Ready and Control outputs ■ Integrated, Industry Standard Enhanced 8051 ❐ 48 MHz, 24 MHz, or 12 MHz CPU operation ❐ Four clocks per instruction cycle ❐ Three counter/timers ❐ Expanded interrupt system ❐ Two data pointers ■ 1.8 V Core Operation ■ 1.8 V to 3.3 V I/O Operation ■ Vectored USB Interrupts and GPIF/FIFO Interrupts ■ Separate Data Buffers for Setup and Data Portions of a CONTROL Transfer ■ Integrated I2C Controller, runs at 100 or 400 kHz ■ Four Integrated FIFOs ❐ Integrated glue logic and FIFOs lower system cost ❐ Automatic conversion to and from 16-bit buses ❐ Master or slave operation ❐ Uses external clock or asynchronous strobes ❐ Easy interface to ASIC and DSP ICs ■ Available in Industrial Temperature Grade ■ Available in one Pb-free Package with up to 24 GPIOs ❐ 56-pin VFBGA (24 GPIOs) CY7C68053应用: There are a wide variety of applications for the MoBL-USB FX2LP18. It is used in cell phones, smart phones, PDAs, and MP3 players, to name a few. 图1.CY7C68053方框图 CY3687 MoBL-USB FX2LP18开发板 The CY3687 MoBL-USB™ FX2LP18 Development Kit (DVK) is the best starting point for developing a MoBL-USB based product. The DVK includes a development board, code example, a generic device driver, documentation, and assorted tools. This guide provides a general overview and installation help for the DVK. The software installation of the kit includes additional help files and documentation more specific to the various components in the kit. 图2.MoBL-USB FX2LP18开发板外形图 CY3687 MoBL-USB FX2LP18 Development Board Details MoBL-USB FX2LP18开发板包括: The following list shows the components supplied in the CY3687 MoBL-USB FX2LP18 Development Kit. They represent most of the development tools required to build a USB system. 硬件: ■ MoBL-USB FX2LP18 development board ■ Prototyping board (‘breadboard’). This board is compatible with the EZ-USB (FX1/FX2LP) developments kits as well. ■ USB cable ■ RS-232 cable ■ Software Installation CD-ROM ■ Quick start Guide Booklet ■ 3 sample MOBL-USB FX2LP18 IC(CY7C68053-56BAXI) 图3.MoBL-USB FX2LP18开发板电路图 MoBL-USB FX2LP18开发板材料清单: 详情请见: 和 来源:网络 |
