Renesas RX630系列32位MCU开发方案
发布时间:2012-7-10 12:19
发布者:1770309616
Renesas公司的RX630系列是32位MCU,工作频率最大为100MHz,100MHz时的性能为165 DMIPS,具有单精度32位IEEE-754浮点,两种类型的乘法和累加器,工作电压2.7V-3.6V,主要用在嵌入式系统.本文介绍了RX630系列主要特性,方框图,RX630系列评估板主要特性与指标,方框图,电路图和元件布局图. RX630系列主要特性: ■ 32-bit RX CPU core Max. operating frequency: 100 MHz Capable of 165 DMIPS in operation at 100 MHz Single precision 32-bit IEEE-754 floating point Two types of multiply-and-accumulation unit (between memories and between registers) 32-bit multiplier (fastest instruction execution takes one CPU clock cycle) Divider (fastest instruction execution takes two CPU clock cycles) Fast interrupt CISC Harvard architecture with 5-stage pipeline Variable-length instructions: Ultra-compact code Supports the memory protection unit (MPU) JTAG and FINE (two-line) debugging interfaces ■ Low-power design and architecture Operation from a single 2.7- to 3.6-V supply Low power consumption: A product that supports all peripheral functions draws only 500 μA/MHz. RTC is capable of operation from a dedicated power supply (min. operating voltage: 2.3 V). Four low-power modes ■ On-chip main flash memory, no wait states 100-MHz operation, 10-ns read cycle (no wait states) 384-Kbyte to 2-Mbyte capacities User code programmable via the USB, SCI, or JTAG ■ On-chip data flash memory Max. 32 Kbytes, reprogrammable up to 100,000 times Programming/erasing as background operations (BGOs) ■ On-chip SRAM, no wait states 32- to 128-Kbyte capacities For instructions and operands Can provide backup on deep software standby ■ DMA DMAC: Incorporates four channels DTC ■ Reset and supply management Power-on reset (POR) Low voltage detection (LVD) with voltage settings ■ Clock functions External crystal oscillator or internal PLL for operation at 4 to 16 MHz Internal 125-kHz LOCO and 50-MHz HOCO Dedicated 125-kHz LOCO for the IWDT Frequency of the oscillator for sub-clock generation: 32 kHz ■ Real-time clock Adjustment functions (30 seconds, leap year, and error) Time capture function (for capturing times in response to event-signal input on external pins) ■ Independent watchdog timer 125-kHz LOCO clock operation ■ Useful functions for IEC60730 compliance Oscillation-stop detection, frequency measurement, CRC, IWDT, self-diagnostic function for the A/D converter, etc. ■ Up to 22 communications interfaces USB 2.0 full-speed function interface (1 channel) CAN (compliant with ISO11898-1), incorporating 32 mailboxes (up to 3 channels) SCI with multiple functionalities (up to 13 channels) Choose from among asynchronous mode, clock-synchronous mode, smart-card interface mode, simple SPI, simple I2C, and extended serial mode. I2C bus interface for transfer at up to 1 Mbps (up to 4 channels) RSPI for high-speed transfer (up to 3 channels) ■ External address space 8 CS areas (8 × 16 Mbytes) Multiplexed address data or separate address lines are selectable per area. 8-, 16-, or 32-bit bus space is selectable per area ■ Up to 20 extended-function timers 16-bit MTU2: input capture, output capture, complementary PWM output, phase-counting mode (6 channels) 16-bit TPU: input capture, output capture, phase-counting mode (12 channels) 8-bit TMR (4 channels) 16-bit compare-match timers (4 channels) ■ A/D converter for 1-MHz Operation Up to 21 12-bit channels, and incorporating 1 sample-and-hold circuit Up to 8 10-bit channels, and incorporating 1 sample-and-hold circuit Addition of results of A/D conversion (in the 12-bit A/D converter) Self diagnosis (for the 10-bit A/D converter) ■ 10-bit D/A converter: 2 channels ■ Temperature sensor for measuring temperature within the chip ■ Register write protection function can protect values in important registers against overwriting. ■ Up to 148 pins for GPIO 5-V tolerance, open drain, input pull-up, switchable driving ability ■ Operating temp. range –40 degree C to +85 degree C 图1.RX630系列方框图 RX630系列评估板 The Renesas Starter Kit for RX630 is intended as a user-friendly introductory and evaluation tool for the RX630 microcontroller. The kit also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging. This includes a choice of IDEs between the High-performance Embedded Workshop and e2studio. The Renesas Starter Kit for RX630 may be connected to the host PC using a simple RS232 serial connection or via the included USB E1 on chip debugging interface. The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools. This RSK is an evaluation tool for Renesas microcontrollers. This manual describes the technical details of the RSK hardware. The Quick Start Guide and Tutorial Manual provide details of the software installation and debugging environment. RX630系列评估板主要特性: This RSK provides an evaluation of the following features: Renesas microcontroller programming User code debugging User circuitry such as switches, LEDs and a potentiometer Sample application Sample peripheral device initialisation code The RSK board contains all the circuitry required for microcontroller operation. 图2.RX630系列评估板方框图 The LCD display module is supplied as a detachable sub-board. The board dimensions are 120 mm by 100 mm, detailed dimensions are available in the user manual. 图3.RX630系列评估板元件布局图 RX630系列评估板主要指标:
图4.RX630系列评估板外形图 图5.RX630系列评估板电路图(1) 图6.RX630系列评估板电路图(2) 图7.RX630系列评估板电路图(3) 图8.RX630系列评估板电路图(4) 图9.RX630系列评估板电路图(5) 图10.RX630系列评估板电路图(6) 图11.RX630系列评估板元件布局图:顶层 图12.RX630系列评估板元件布局图:底层 详情请见: 和 以及 来源:网络 |
