ST STP4CMP带电荷泵四路LED驱动解决方案
发布时间:2012-7-9 11:22
发布者:1770309616
ST公司的STP4CMP是基于电荷泵的四路LED驱动器,设计用于RGB照明或LCD显示器背光.支持正向电压高达成3.8V的LED,工作电压 2.7 V到5.5 V,四路电流可单独编程,最大电流30mA,输出电流精度 ±7%,通路间电流匹配度在 ±4%内.主要用在手机显示器背光和RGB LED指示器驱动器.本文介绍了STP4CMP主要特性,框图,典型应用电路及其所用元件,STP4CMP评估板及其电路图,STEVAL-TLL012V1演示板主要特性和电路图,材料清单. The STP4CMP is a charge pump based 4-channel LED driver designed for RGB illumination or LCD display backlighting. The STP4CMP works off a battery with an input voltage between 2.7 V - 5.5 V. The device generates regulated current sinks with high absolute and channel-tochannel accuracy to drive up to 4 LEDs. It can support LEDs with forward voltage as high as 3.8 V. The current sink for each channel can be set with 4 individual external resistors. Each channel is controlled independently. The PWM control can be applied directly to the 4 EN (enable) pins to provide brightness control. When enabled, the charge pump, which uses a small ceramic bucket capacitor between C1P and C1N, operates to regulate the VOUT with a clamping voltage at typ. 5 V. The tiny QFN20 (1.8 x 3.2 mm) package allows the device to be also used for applications with space limitation. STP4CMP主要特性: ■ Operating voltage range: VCC (opr) = 2.7 V to 5.5 V ■ Full RGB function support ■ 4-channel LED driver with individual ON/OFF control directly from input pins ■ Individual programmable output current for the 4 channels through 4 external resistors with a max. capability of 30 mA ■ Absolute output current accuracy of max. ±7% and channel-to-channel mismatch of max. ± 4% ■ Selectable charge pump enable/disable ■ Thermal protection ■ Small QFN20 (1.8 x 3.2 mm) package STP4CMP应用: ■ Mobile phone display backlighting ■ RGB LED indicator drivers 图1.STP4CMP方框图 图2.STP4CMP应用框图 图2应用电路外接元件: 图3.STP4CMP评估板外形图 图4.STP4CMP评估板电路图 STEVAL-TLL012V1演示板 The STEVAL-TLL012V1 demonstration board demonstrates the performance of the STP4CMP, a charge pump based 4-channel LED driver designed for RGB illumination or LCD display backlighting. This device works off a battery with an input voltage between 2.7 V - 5.5 V. The device generates regulated current sinks with high absolute and channel-to-channel accuracy to drive up to 4 LEDs. It can support LEDs with forward voltage as high as 3.8 V. The current sink for each channel can be set with 4 individual external resistors. Each channel is controlled independently. The PWM control can be applied directly to the 4 EN (enable) inputs to provide brightness control. STEVAL-TLL012V1演示板主要特性: ■ Operating voltage range: 2.7 V to 5.5 V ■ Full RGB function support ■ 4-channel LED driver with individual ON/OFF control directly from input pins ■ Individual programmable output current for the 4 channels through 4 external resistors with a max. capability of 30 mA ■ Absolute output current accuracy of max. ±7% and channel-to-channel mismatch of max. ± 4% ■ Selectable charge pump enable/disable ■ Thermal protection ■ RoHS compliant 图5.STEVAL-TLL012V1演示板外形图 图6.STEVAL-TLL012V1演示板电路图 STEVAL-TLL012V1演示板材料清单: 详情请见: 和 来源:网络 |
