查看: 6275|回复: 8
PADS9.4有重大BUG,撤销下载
发表于 2012-3-16 08:32:42 | 显示全部楼层 |阅读模式
Dear PADS Customer,
You are receiving this email because you have recently downloaded the PADS 9.4 release from SupportNet.
A critical defect has been identified in the release - DR 873769.  If you do not have the Advanced Rules Set (ARS) option, the system will crash if you attempt to open the Padstack dialog in the Decal Editor.
If you have ARS, this defect will not affect you.
If you do not have ARS, we strongly recommend that you uninstall PADS 9.4 and revert to PADS 9.3.1 (or your previous version) to continue your work. For any PCB designs saved in PADS 9.4 format, please ASCII export the design to PADS 9.3 format first.
A version of PADS with this defect fixed is expected to be available on SupportNet within a week.
We apologize for any inconvenience this issue may have caused, and commit to improving our development process and restoring your confidence in us.
发表于 2012-3-16 09:07:08 | 显示全部楼层
天哪,大bug也敢发布
发表于 2012-3-16 09:36:35 | 显示全部楼层
看了下,俺用的是PADS9.0的绿色精简版
发表于 2012-3-16 10:33:24 | 显示全部楼层
哈哈,俺的是PADS2007,更加没问题,yeah!
发表于 2012-3-16 11:53:34 | 显示全部楼层
THanks
发表于 2012-3-16 13:24:14 | 显示全部楼层
亡羊补牢,为时未晚!
发表于 2012-3-29 09:34:41 | 显示全部楼层
还没有升级到9.4。
发表于 2013-5-4 09:28:21 | 显示全部楼层
受教育了!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2015-2-4 12:03:17 | 显示全部楼层
支持一下
