ST STEVAL-IHM021V2 100W马达矢量控制方案
发布时间:2012-2-16 13:59
发布者:1770309616
ST公司的STEVAL-IHM021V2是采用L6390和STD5N52U的3相马达控制板,用于永磁同步马达(PMSM) 矢量控制,正常输出功率高达100W,和110VAC与230VAC火线电压兼容,主要用在冰箱压缩机和洗碗机.本文介绍了L6390主要特性, 方框图和应用框图,以及采用L6390和STD5N52U的100W三相马达矢量控制板STEVAL-IHM021V2主要特性,方框图,电路图和材料清单. The L6390 is a high-voltage device manufactured with the BCD “OFF-LINE” technology. It is a single chip half-bridge gate driver for N-channel power MOSFET or IGBT. The high side (floating) section is designed to stand a voltage rail up to 600 V. The logic inputs are CMOS/TTL compatible down to 3.3 V for easy interfacing microcontroller/DSP. The IC embeds an operational amplifier suitable for advanced current sensing in applications such as field oriented motor control. An integrated comparator is available for protections against overcurrent, overtemperature, etc. L6390主要特性: ■ High voltage rail up to 600 V ■ dV/dt immunity ± 50 V/nsec in full temperature range ■ Driver current capability: – 290 mA source, – 430 mA sink ■ Switching times 75/35 nsec rise/fall with 1 nF load ■ 3.3 V, 5 V TTL/CMOS inputs with hysteresis ■ Integrated bootstrap diode ■ Operational amplifier for advanced current sensing ■ Comparator for fault protections ■ Smart shut down function ■ Adjustable dead-time ■ Interlocking function ■ Compact and simplified layout ■ Bill of material reduction ■ Effective fault protection ■ Flexible, easy and fast design L6390应用: ■ Motor driver for home appliances, factory automation, industrial drives. ■ HID ballasts, power supply units. 图1.L6390方框图 图2.L6390应用框图 采用L6390和STD5N52U的100W三相马达矢量控制演示板STEVAL-IHM021V2 The 100 W 3-phase inverter demonstration board features the L6390 and STD5N52U for field-oriented control (FOC) of permanent magnet synchronous motors (PMSM). Also referred to by order code STEVAL-IHM021V2, this 3-phase inverter is designed to perform the FOC of sinusoidal-shaped back-EMF PMSMs with or without sensors, with nominal power up to 100 W. The flexible, open, high-performance design consists of a 3-phase inverter bridge based on: ■ the STD5N52U power MOSFET in a DPAK package, with enhanced fast body-drain recovery diode ■ the L6390 device, which is part of the latest high-voltage half-bridge gate driver family featuring an integrated comparator for implementation of hardware protection (i.e. overcurrent, overtemperature, etc.) ■ an embedded operational amplifier suitable for advanced current sensing The system is specifically designed to achieve fast and accurate conditioning of the current feedback, thereby matching the requirements typical of high-end applications such as fieldoriented motor control. As an alternative to the STD5N52U, the STGD6NC60HD or STGDL6NC60DI IGBT devices may be used on the board without replacing the switch driving network. The board is compatible with 110 and 230 Vac mains, and includes a power supply stage with the VIPer12A-E (in buck configuration) to generate the +15 V and +3.3 V supply voltage required by the application. Finally, the board can be interfaced with the STM3210B-EVAL (STM32 microcontroller demonstration board) through a dedicated connector. 图3.STEVAL-IHM021V2演示板外形图 The STEVAL-IHM021V2 100 W 3-phase inverter has the following characteristics: ● Wide range input voltage ● Maximum power up to 100 W at 230 Vac input ● The STD5N52U 4.4 A, 520 V power MOSFET ● Compatibility with other power switches in DPAK packages (the STGD6NC60HD or STGDL6NC60DI, for example) ● 15 V auxiliary power supply connector ● Connector for interfacing with the STM3210B-EVAL board STEVAL-IHM021V2演示板目标应用: ● Refrigerator compressors ● Dishwasher pumps 图4.STEVAL-IHM021V2演示板方框图 图5.STEVAL-IHM021V2演示板电源框图 图6.STEVAL-IHM021V2演示板逆变器电路图 图7.STEVAL-IHM021V2演示板电源电路图 STEVAL-IHM021V2演示板材料清单: 详情请见: |
