TI LM3S818三相无刷直流(BLDC)马达驱动方案
发布时间:2011-12-29 12:41
发布者:1046235000
TI公司的LM3S818工作频率高达50MHz的基于ARM® Cortex™-M3控制器核的32位MCU,具有32位RISC性能,集成了64kB闪存和8kB SRAM,并具有实时工业连接,SSI/SPI控制器,和2个UART. LM3S818具有6个运动控制PWM输出,用于位置监视的正交编码器以及低等待关断的故障保护输入.目标应用在工厂自动化和控制,建筑物和家庭自动化,步进马达, 无刷直流(BLDC)马达和交流感应电动机.本文介绍了LM3S818主要特性,方框图, Stellaris® LM3S818 controlCARD模块主要特性,框图,电路图和模块元件布局图. The Stellaris® LM3S818 microcontroller is based on the ARM® Cortex™-M3 controller core operating at up to 50 MHz, with 64 kB flash and 8 kB SRAM. The LM3S818 also features real-time industrial connectivity, with an SSI / SPI controller, and 2 UARTs. The LM3S818 microcontroller also features advanced motion control features, including 6 motion-control PWM outputs with dead-band, a quadrature encoder input for precise position monitoring, and a fault protection input for low-latency shutdown. The microcontroller also features intelligent analog capability, including 1 analog comparators and 6 channels of highly accurate 10-bit analog-to-digital conversion - with the ability to sample at speeds of 1M samples per second. LM3S818主要特性: The LM3S818 microcontroller includes the following product features: ■ 32-Bit RISC Performance – 32-bit ARM® Cortex™-M3 v7M architecture optimized for small-footprint embedded Applications – System timer (SysTick), providing a simple, 24-bit clear-on-write, decrementing, wrap-on-zero counter with a flexible control mechanism – Thumb®-compatible Thumb-2-only instruction set processor core for high code density – 50-MHz operation – Hardware-division and single-cycle-multiplication – Integrated Nested Vectored Interrupt Controller (NVIC) providing deterministic interrupt handling – 26 interrupts with eight priority levels – Memory protection unit (MPU), providing a privileged mode for protected operating system functionality – Unaligned data access, enabling data to be efficiently packed into memory – Atomic bit manipulation (bit-banding), delivering maximum memory utilization and streamlined peripheral control ARM® Cortex™-M3 Processor Core – Compact core. – Thumb-2 instruction set, delivering the high-performance expected of an ARM core in the memory size usually associated with 8- and 16-bit devices; typically in the range of a few kilobytes of memory for microcontroller class applications. – Rapid application execution through Harvard architecture characterized by separate buses for instruction and data. – Exceptional interrupt handling, by implementing the register manipulations required for handling an interrupt in hardware. – Deterministic, fast interrupt processing: always 12 cycles, or just 6 cycles with tail-chaining – Memory protection unit (MPU) to provide a privileged mode of operation for complex applications. – Migration from the ARM7™ processor family for better performance and power efficiency. – Full-featured debug solution • Serial Wire JTAG Debug Port (SWJ-DP) • Flash Patch and Breakpoint (FPB) unit for implementing breakpoints • Data Watchpoint and Trigger (DWT) unit for implementing watchpoints, trigger resources, and system profiling • Instrumentation Trace Macrocell (ITM) for support of printf style debugging • Trace Port Interface Unit (TPIU) for bridging to a Trace Port Analyzer – Optimized for single-cycle flash usage – Three sleep modes with clock gating for low power – Single-cycle multiply instruction and hardware divide – Atomic operations – ARM Thumb2 mixed 16-/32-bit instruction set – 1.25 DMIPS/MHz ■ JTAG – IEEE 1149.1-1990 compatible Test Access Port (TAP) controller – Four-bit Instruction Register (IR) chain for storing JTAG instructions – IEEE standard instructions: BYPASS, IDCODE, SAMPLE/PRELOAD, EXTEST and INTEST – ARM additional instructions: APACC, DPACC and ABORT Integrated ARM Serial Wire Debug (SWD) ■ Internal Memory – 64 KB single-cycle flash • User-managed flash block protection on a 2-KB block basis • User-managed flash data programming • User-defined and managed flash-protection block – 8 KB single-cycle SRAM ■ GPIOs – 0-30 GPIOs, depending on configuration – 5-V-tolerant in input configuration – Programmable control for GPIO interrupts • Interrupt generation masking • Edge-triggered on rising, falling, or both • Level-sensitive on High or Low values – Bit masking in both read and write operations through address lines – Can initiate an ADC sample sequence – Pins configured as digital inputs are Schmitt-triggered. – Programmable control for GPIO pad configuration • Weak pull-up or pull-down resistors • 2-mA, 4-mA, and 8-mA pad drive for digital communication • Slew rate control for the 8-mA drive • Open drain enables • Digital input enables ■ General-Purpose Timers – Three General-Purpose Timer Modules (GPTM), each of which provides two 16-bit timers/counters. Each GPTM can be configured to operate independently: • As a single 32-bit timer • As one 32-bit Real-Time Clock (RTC) to event capture • For Pulse Width Modulation (PWM) • To trigger analog-to-digital conversions – 32-bit Timer modes • Programmable one-shot timer • Programmable periodic timer • Real-Time Clock when using an external 32.768-KHz clock as the input • User-enabled stalling when the controller asserts CPU Halt flag during debug • ADC event trigger – 16-bit Timer modes • General-purpose timer function with an 8-bit prescaler (for one-shot and periodic modes only) • Programmable one-shot timer • Programmable periodic timer • User-enabled stalling when the controller asserts CPU Halt flag during debug • ADC event trigger – 16-bit Input Capture modes • Input edge count capture • Input edge time capture – 16-bit PWM mode • Simple PWM mode with software-programmable output inversion of the PWM signal ■ ARM FiRM-compliant Watchdog Timer – 32-bit down counter with a programmable load register – Separate watchdog clock with an enable – Programmable interrupt generation logic with interrupt masking – Lock register protection from runaway software – Reset generation logic with an enable/disable – User-enabled stalling when the controller asserts the CPU Halt flag during debug ■ ADC – Six analog input channels – Single-ended and differential-input configurations On-chip internal temperature sensor – Sample rate of one million samples/second – Flexible, configurable analog-to-digital conversion – Four programmable sample conversion sequences from one to eight entries long, with corresponding conversion result FIFOs – Flexible trigger control • Controller (software) • Timers • Analog Comparators • PWM • GPIO – Hardware averaging of up to 64 samples for improved accuracy – Converter uses an internal 3-V reference ■ UART – Two fully programmable 16C550-type UARTs – Separate 16x8 transmit (TX) and receive (RX) FIFOs to reduce CPU interrupt service loading – Programmable baud-rate generator allowing speeds up to 3.125 Mbps – Programmable FIFO length, including 1-byte deep operation providing conventional double-buffered interface – FIFO trigger levels of 1/8, 1/4, 1/2, 3/4, and 7/8 – Standard asynchronous communication bits for start, stop, and parity – Line-break generation and detection – Fully programmable serial interface characteristics • 5, 6, 7, or 8 data bits • Even, odd, stick, or no-parity bit generation/detection • 1 or 2 stop bit generation ■ Synchronous Serial Interface (SSI) – Master or slave operation – Programmable clock bit rate and prescale Separate transmit and receive FIFOs, 16 bits wide, 8 locations deep – Programmable interface operation for Freescale SPI, MICROWIRE, or Texas Instruments synchronous serial interfaces – Programmable data frame size from 4 to 16 bits – Internal loopback test mode for diagnostic/debug testing ■ Analog Comparators – One integrated analog comparator – Configurable for output to drive an output pin, generate an interrupt, or initiate an ADC sample sequence – Compare external pin input to external pin input or to internal programmable voltage reference – Compare a test voltage against any one of these voltages • An individual external reference voltage • A shared single external reference voltage • A shared internal reference voltage ■ PWM – Three PWM generator blocks, each with one 16-bit counter, two PWM comparators, a PWM signal generator, a dead-band generator, and an interrupt/ADC-trigger selector – One fault input in hardware to promote low-latency shutdown – One 16-bit counter • Runs in Down or Up/Down mode • Output frequency controlled by a 16-bit load value • Load value updates can be synchronized • Produces output signals at zero and load value – Two PWM comparators • Comparator value updates can be synchronized • Produces output signals on match – PWM generator • Output PWM signal is constructed based on actions taken as a result of the counter and PWM comparator output signals • Produces two independent PWM signals Dead-band generator • Produces two PWM signals with programmable dead-band delays suitable for driving a half-H bridge • Can be bypassed, leaving input PWM signals unmodified – Flexible output control block with PWM output enable of each PWM signal • PWM output enable of each PWM signal • Optional output inversion of each PWM signal (polarity control) • Optional fault handling for each PWM signal • Synchronization of timers in the PWM generator blocks • Synchronization of timer/comparator updates across the PWM generator blocks • Interrupt status summary of the PWM generator blocks – Can initiate an ADC sample sequence ■ QEI – Position integrator that tracks the encoder position – Velocity capture using built-in timer – The input frequency of the QEI inputs may be as high as 1/4 of the processor frequency (for example, 12.5 MHz for a 50-MHz system) – Interrupt generation on: • Index pulse • Velocity-timer expiration • Direction change • Quadrature error detection ■ Power – On-chip Low Drop-Out (LDO) voltage regulator, with programmable output user-adjustable from 2.25 V to 2.75 V – Low-power options on controller: Sleep and Deep-sleep modes – Low-power options for peripherals: software controls shutdown of individual peripherals – User-enabled LDO unregulated voltage detection and automatic reset – 3.3-V supply brown-out detection and reporting via interrupt or reset ■ Flexible Reset Sources – Power-on reset (POR) – Reset pin assertion – Brown-out (BOR) detector alerts to system power drops – Software reset – Watchdog timer reset – Internal low drop-out (LDO) regulator output goes unregulated ■ Industrial and extended temperature 48-pin RoHS-compliant LQFP package ■ Industrial and extended temperature 48-pin RoHS-compliant QFN package LM3S818目标应用: ■ Factory automation and control ■ Industrial control power devices ■ Building and home automation ■ Stepper motors ■ Brushless DC motors ■ AC induction motors 图1. Stellaris LM3S818 MCU方框图 图2. LM3S818控制器系统级框图 Stellaris® LM3S818 controlCARD模块 The Stellaris® LM3S818 controlCARD module is a DIMM form-factor module that can be used standalone or with a range of baseboards to accelerate evaluation and development. Texas Instruments offers a range of controlCARD baseboards for motor and power-control application. In most cases. these are available as complete kits that include a controlCARD module and a baseboard. The Stellaris MDL-LM3S818CNCD is part of a controlCARD lineup that includes cards for C2000 and MSP430 devices. 图3. LM3S818 controlCARD三相BLDC马达模块外形图 LM3S818 controlCARD模块包括: The LM3S818 controlCARD module kit comes with the following: MDL-LM3S818CNCD controlCARD module – On board Stellaris In-Circuit Debug Interface Cables/Accessories – USB-miniB to USB-A plug cable (for debug and serial communication) – 1/2-inch blue jumper wires (for bridging power) Development Kit CD containing: – For the controlCARD module in standalone use: • Complete documentation • StellarisWare® Peripheral Driver Library and example source code – For the controlCARD module when used with a supported baseboard: • Source-code and binaries • Documentation specific to each supported baseboard • CrossHairs control GUI Windows application Tools CD(s) Texas Instruments’ Code Composer Studio™ IDE Stellaris MDL-LM3S818CNCD controlCARD模块主要特性: The Stellaris MDL-LM3S818CNCD controlCARD module includes the following features: LM3S818IQN50 Stellaris microcontroller – 32-bit ARM® Cortex™-M3 core – 50 MHz max speed – 64 KB Flash, 8 KB RAM DIMM form-factor GPIO signals available on DIMM edge-connector User LED Debug – Stellaris In-Circuit Debug Interface (ICDI) Isolated to 560 V working-voltage using Texas’Instruments’ digital isolators 图4. LM3S818 controlCARD模块方框图 图5. LM3S818 controlCARD模块电路图(1) 图6. LM3S818 controlCARD模块电路图(2) 图7. LM3S818 controlCARD模块元件布局图:上图:顶层,下图:底层 详情请见: |
