TI DRV8833马达驱动解决方案
发布时间:2011-12-20 12:23
发布者:1770309616
TI公司的DRV8833是双桥马达驱动器解决方案,包括有两个H桥驱动器,可驱动两个DC电刷马达,或一个步进马达, 螺线管和其它电感负载. DRV8833具有PWM绕组电流调整/限制,H桥的输出电流1.5A RMS,2A峰值,工作电压2.7V-10.8V,主要用在电池玩具,视频照相鸡,办公室自动设备,游戏机和机器人.本文介绍了DRV8833主要特性,方框图,应用电路以及DRV8833评估模块电路图. The DRV8833 provides a dual bridge motor driver solution for toys, printers, and other mechatronic applications. The device has two H-bridge drivers, and can drive two DC brush motors, a bipolar stepper motor, solenoids, or other inductive loads. The output driver block of each H-bridge consists of N-channel power MOSFET’s configured as an H-bridge to drive the motor windings. Each H-bridge includes circuitry to regulate or limit the winding current. With proper PCB design, each H-bridge of the DRV8833 is capable of driving up to 1.5-A RMS (or DC) continuously, at 25°C with a VM supply of 5 V. It can support peak currents of up to 2 A per bridge. Current capability is reduced slightly at lower VM voltages. Internal shutdown functions with a fault output pin are provided for over current protection, short circuit protection, under voltage lockout and overtemperature. A low-power sleep mode is also provided. The DRV8833 is packaged in a 16-pin HTSSOP or QFN package with PowerPAD™ (Eco-friendly: RoHS & no Sb/Br). DRV8833主要特性: • PWM Winding Current Regulation/Limiting • Thermally Enhanced Surface Mount Package 2 • Dual-H-Bridge Current-Control Motor Driver – Capable of Driving Two DC Motors or One Stepper Motor – Low MOSFET On-Resistance: HS + LS 360 mΩ • POS Printers • Output Current 1.5-A RMS, 2-A Peak per H-Bridge (at VM = 5 V, 25°C) • Outputs Can Be Paralleled for 3-A RMS, 4-A Peak • Wide Power Supply Voltage Range: 2.7 V – 10.8 V DRV8833应用: • Battery-Powered Toys • Video Security Cameras • Office Automation Machines • Gaming Machines • Robotics 图1. DRV8833方框图 图2. DRV8833并行模式应用电路图 DRV8833评估模块 图3. DRV8833评估模块电路图 图4. DRV8833评估模块元件布局图 详情请见: |
