【机器视觉】堡盟发布200W像素视觉传感器
发布时间:2011-11-22 21:47
发布者:hztest
The convenient C-Mount VeriSens vision sensors with integrated flash controller and up to 2 MP resolution
These two advantages combined, provide extremely simple integration and flexible system solutions. The C-Mount design introduces complete freedom of lens selection – even for complex applications. At the same time, the integrated flash controller significantly reduces the cost of typically employed external light solutions. External lighting can be flashed with up to 48 V and 4 A while its configuration is already included in the intuitive software of the VeriSens. This combination gives the user more time to implement his application solution and completely abolishes the need for familiarization with the programming of an external flash controller. CCD sensors with three different resolutions – ranging from VGA to 2 megapixels – will be available with the VeriSens XC series. An extensive software update will also be supplied to support the system’s multiple range of functions. New options, such as an extended statistical assessment are added to the functions already familiar from previous VeriSens series. The integrated test environment for listed jobs allows the setup to be verified and documented more comprehensively before production is started. The integrated FTP functionality simplifies image storage on external media and new tools for distance determination add further possibilities for a complete production control. 14. November 2011 |
