Renesas SH7264音频设备开发方案
发布时间:2011-10-19 17:32
发布者:1046235000
Renesas公司的SH7264是SH7260系列控制器, SH2A-FPU 32位CPU核,最大工作频率144MHz,具有极好的信号处理性能和ROM代码效率,使得音频应用如MP3, WMA或 AAC数据格式的压缩和解压更快,从而降低了程度的大小.主要用在汽车音频,HDD音频和网络音频,汽车图像仪表盘和汽车信息显示以及工业设备如定序器,机器人等.本文介绍了SH7264主要性能指标,方框图, 入门开发板主要指标,方框图和电路图,主要元件布局图以及音频DJ设备系统方框图. Renesas Electronics had earlier launched the SH7260 Series of microcontrollers, built around the SH2A-FPU 32-bit CPU core with superb real time processing capability, as a solution for the digital audio field. The SH7262 and SH7264 belong to the SH7260 Series of microcontrollers, and the maximum operating frequency of 144 MHz enables faster operation in applications such as equipment control or digital audio signal processing. This combination of excellent signal processing performance and ROM code efficiency means that compression and decompression of audio data in formats required by digital audio applications, such as MP3, WMA, or AAC (Advanced Audio Coding), is performed more quickly and program sizes are reduced. Thanks to the newly added large-capacity SRAM, not only processing tasks related to equipment control and digital audio, but also video display capabilities can be implemented on as ingle chip. An ample 1 Mbyte or 640-Kbyte of on-chip SRAM is provided for video display use. It can be configured as a frame buffer to store video data temporarily, which is necessary when implementing graphical display capabilities. The generous SRAM capacity means that it is possible to use a TFTLCD panel display up to WQVGA size (480 × 240 pixels) without the need for external SDRAM as video memory. The SH7262 and SH7264 provide a new video display controller and digital video input pins for use with graphical and video display applications. Digital RGB output pins allow output of images or video in RGB565 format at up to WQVGA size (480 × 240 pixels). This reduces the total number of devices required and helps lower both the cost and the power consumption of the system. This LSI is a single-chip RISC (reduced instruction set computer) microcontroller that includes a Renesas-original RISC CPU as its core, and the peripheral functions required to configure a system. The CPU in this LSI is an SH-2A CPU, which provides upward compatibility for SH-1, SH-2, and SH-2E CPUs at object code level. It has a RISC-type instruction set, superscalar architecture, and Harvard architecture, for superior rates of instruction execution. In addition, the 32-bit internal-bus architecture that is independent from the direct memory access controller enhances data processing power. This CPU brings the user the ability to set up high-performance systems with strong functionality at less expense than was achievable with previous microcontrollers, and is even able to handle realtime control applications requiring high-speed characteristics. This LSI has a floating-point unit and cache. In addition, this LSI includes on-chip peripheral functions necessary for system configuration, such as a 64-Kbyte RAM for high-speed operation, a 1-Mbyte or 640-Kbyte large-capacity RAM (32-Kbytes for 1-Mbyte and 320-Kbytes for 640-Kbyte versions are shared by the data-retention RAM), multi-function timer pulse unit 2, compare match timer, realtime clock, serial communication interface with FIFO, I2C bus interface 3, serial sound interface, serial I/O with FIFO, controller area network interface*2, IEBusTM*1 controller*2, Renesas SPDIF interface, CD-ROM decoder , A/D converter, NAND flash memory controller, USB 2.0 host/function, video display controller 3, sampling rate converter, SD host interface, decompression unit, motor control PWM timer, and interrupt controller modules, and general I/O ports. This LSI also provides an external memory access support function to enable direct connection to various memory devices or peripheral LSIs. These on-chip functions significantly reduce costs of designing and manufacturing application systems. SH7264主要指标: CPU Renesas original SuperH architecture Compatible with SH-1, SH-2, and SH-2E at object code level 32-bit internal data bus Support of an abundant register-set ⎯Sixteen 32-bit general registers ⎯Four 32-bit control registers ⎯Four 32-bit system registers ⎯Register bank for high-speed response to interrupts RISC-type instruction set (upward compatible with SH series) ⎯Instruction length: 16-bit fixed-length basic instructions for improved code efficiency and 32-bit instructions for high performance and usability ⎯Load/store architecture ⎯Delayed branch instructions ⎯Instruction set based on C language Superscalar architecture to execute two instructions at one time including a floating-point unit Instruction execution time: Up to two instructions/cycle Address space: 4 Gbytes Internal multiplier Five-stage pipeline Harvard architecture Floating-point unit Floating-point co-processor included Supports single-precision (32-bit) and double-precision (64-bit) Supports data type and exceptions that conforms to IEEE754 standard Two rounding modes: Round to nearest and round to zero Two denormalization modes: Flush to zero Floating-point registers ⎯Sixteen 32-bit floating-point registers (single-precision 16 words or double-precision 8 words) ⎯Two 32-bit floating-point system registers Supports FMAC (multiplication and accumulation) instructions Supports FDIV (division) and FSQRT (square root) instructions Supports FLDI0/FLDI1 (load constant 0/1) instructions Instruction execution time ⎯Latency (FMAC/FADD/FSUB/FMUL): Three cycles (singleprecision), eight cycles (double-precision) ⎯itch (FMAC/FADD/FSUB/FMUL): One cycle (single-precision), six cycles (double-precision) Note: FMAC only supports single-precision Five-stage pipeline Cache memory Instruction cache: 8 Kbytes Operand cache: 8 Kbytes 128-entry/way, 4-way set associative, 16-byte block length configuration each for the instruction cache and operand cache Write-back, write-through, LRU replacement algorithm Way lock function available (only for operand cache); ways 2 and 3 can be locked Interrupt controller Seventeen external interrupt pins (NMI, IRQ7 to IRQ0, and PINT7 to PINT0) On-chip peripheral interrupts: Priority level set for each module 16 priority levels available Register bank enabling fast register saving and restoring in interrupt processing Bus state controller Address space divided into seven areas (0 to 6), each a maximum of 64 Mbytes The following features settable for each area independently ⎯Bus size (8 or 16 bits): Available sizes depend on the area. ⎯Number of access wait cycles (different wait cycles can be specified for read and write access cycles in some areas) ⎯Idle wait cycle insertion (between the same area access cycles or different area access cycles) ⎯Specifying the memory to be connected to each area enables direct connection to SRAM, SRAM with byte selection, SDRAM, and burst ROM (clocked synchronous or asynchronous). The address/data multiplexed I/O (MPX) interface are also available. ⎯CMCIA interface ⎯Outputs a chip select signal (CS0 to CS6) according to the target area (CS assert or negate timing can be selected by software) SDRAM refresh Auto refresh or self refresh mode selectable SDRAM burst access Direct memory access controller Sixteen channels; external requests are available for one of them in the SH7262 Group, and for two of them in the SH7264 Group. Can be activated by on-chip peripheral modules Burst mode and cycle steal mode Intermittent mode available (16 and 64 cycles supported) Transfer information can be automatically reloaded Clock pulse generator Clock mode: Input clock can be selected from external input (EXTAL or USB_X1) or crystal resonator Input clock can be multiplied by 12 (max.) by the internal PLL circuit Three types of clocks generated: ⎯CPU clock: Maximum 144 MHz ⎯Bus clock: Maximum 72 MHz ⎯eripheral clock: Maximum 36 MHz Watchdog timer On-chip one-channel watchdog timer A counter overflow can reset the LSI Power-down modes Four power-down modes provided to reduce the power consumption in this LSI ⎯Sleep mode ⎯Software standby mode ⎯Deep standby mode ⎯Module standby mode Multi-function timer pulse unit 2 Maximum 16 lines of pulse inputs/outputs based on fix channels of 16-bit timers 18 output compare and input capture registers Input capture function ulse output modes Toggle, PWM, complementary PWM, and reset-synchronized PWM modes Synchronization of multiple counters Complementary PWM output mode ⎯Non-overlapping waveforms output for 3-phase inverter control ⎯Automatic dead time setting ⎯0% to 100% PWM duty value specifiable ⎯A/D converter start request delaying function ⎯Interrupt skipping at crest or trough Reset-synchronized PWM mode Three-phase PWM waveforms in positive and negative phases can be output with a required duty value hase counting mode Two-phase encoder pulse counting available Compare match timer Two-channel 16-bit counters Four types of clock can be selected (P/8, P/32, P/128, and P/512) DMA transfer request or interrupt request can be issued when a compare match occurs Realtime clock Internal clock, calendar function, alarm function Interrupts can be generated at intervals of 1/256 s by the 32.768-kHz on-chip crystal oscillator Serial communication interface with FIFO Eight channels Clocked synchronous or asynchronous mode selectable (SH7262: channels 0 to 2, SH7264: channels 0 to 3) Simultaneous transmission and reception (full-duplex communication) supported Dedicated baud rate generator Separate 16-byte FIFO registers for transmission and reception Modem control function (SH7262: channel 1, SH7264: channels 1 and 3, in asynchronous mode) Renesas serial peripheral interface Two channels SPI operation Master mode and slave mode selectable rogrammable bit length, clock polarity, and clock phase can be selected. Consecutive transfers MSB first/LSB first selectable Maximum transfer rate: 36 Mbps I2C bus interface 3 Three channels Master mode and slave mode supported Serial sound interface Four-channel bidirectional serial transfer Duplex communication (channel 0) Support of various real audio formats Support of master and slave functions Generation of programmable word clock and bit clock Multi-channel formats Support of 8, 16, 18, 20, 22, 24, and 32-bit data formats Support of eight-stage FIFO for transmission and reception Serial I/O with FIFO Support of 16-stage 32-bits FIFOs independently for transmission and reception 8-bit monaural/16-bit monaural/16-bit stereo audio input and output Connectable to linear, audio, or A-Law or -Law CODEC chip Support of master and slave functions Controller area network Note: This module is included or not depending on the product code. Two channels TTCAN level 1 supports for all channels BOSCH 2.0B active compatible Buffer size: transmit/receive 31, receive only 1 Two or more controller area network channels can be assigned to one bus to increase number of buffers with a granularity of 32 channels 31 Mailboxes for transmission or reception IEBusTM controller Note: This module is included or not depending on the product code. IEBus protocol control (layer 2) supported ⎯Half-duplex asynchronous communications ⎯Multi-master system ⎯Broadcast communications function ⎯Selectable mode (three types) with different transfer speeds On-chip buffers (dual port RAM) for data transmission and reception that enable up to 128 bytes of consecutive transmit/reception (maximum number of transfer bytes in mode 2) Operating frequency ⎯12 MHz, 12.58 MHz (1/2 divided clocks of P, AUDIO_X1, or AUDIO_X2.) ⎯18 MHz, 18.87 MHz (1/3 divided clocks of P, AUDIO_X1, or AUDIO_X2.) ⎯24 MHz (1/4 divided clocks of P, AUDIO_X1, or AUDIO_X2.) ⎯25.16 MHz (1/4 divided clocks of P) ⎯30 MHz, 31.45 MHz (1/5 divided clocks of P) ⎯36 MHz (1/6 divided clocks of P) Renesas SPDIF interface Support of IEC60958 standard (stereo and consumer use modes only) Sampling frequencies of 32 kHz, 44.1 kHz, and 48 kHz Audio word sizes of 16 to 24 bits per sample Biphase mark encoding Double buffered data arity encoded serial data Simultaneous transmit and receive Receiver autodetects IEC 61937 compressed mode data CD-ROM decoder Support of five formats: Mode 0, mode 1, mode 2, mode 2 form 1, and mode 2 form 2 Sync codes detection and protection (Protection: When a sync code is not detected, it is automatically inserted.) Descrambling ECC correction ⎯, Q, PQ, and QP correction ⎯Q or QP correction can be repeated up to three times EDC check Performed before and after ECC Mode and form are automatically detected Link sectors are automatically detected Buffering data control Buffering CD-ROM data including Sync code is transferred in specified format, after the data is descrambled, corrected by ECC, and checked by EDC. NAND flash memory controller Direct-connected memory interface with NAND-type flash memory Read/write in sectors Two types of transfer modes: Command access mode and sector access mode (512-byte data + 16-byte management code: with ECC) Interrupt request and DMA transfer request Supports flash memory requiring 5-byte addresses (2 Gbits and more) USB 2.0 host/function module Conforms to the Universal Serial Bus Specification Revision 2.0 480-Mbps, 12-Mbps, and 1.5-Mbps transfer rates provided (host mode) 480-Mbps and 12-Mbps transfer rates provided (function mode) On-chip 8-Kbyte RAM as communication buffers Video display controller 3 Video input Input format: BT601, BT656 (NTSC/PAL) Video recording Can be saved in RGB565 format, at 1/2 field rate. Video processing Video scaling: 1/2, 1/3, 1/4 Horizontal scaling: 1/2, 1/3, 2/3, 1/4 (Each scaling value can be multiplied by 6/7 for PAL.) Adjustment of contrast and brightness Graphic image 1 and 2 (two layers) Input format: RGB565 (16 bits), RGB4444 (16 bits) Overlap function -blending window function: Mixes input image, layer 1, and layer 2 in a specified area according to the transmittance (fadein and face-out possible). Chromakey function: Mixes images according to the specified RGB color and transmittance . Dot a function: Mixes RGB4444-format graphic images according to the transmittance Output image Resolution: VGA (640 480), WQVGA (480 240), QVGA (320 240), QVGA (240 320) Format: RGB565 (16 bits) Sampling rate converter Data format: 32-bit stereo (16 bits each to L/R), 16-bit monaural for channel 0, and 16-bit monaural for channel 1 Input sampling rate: 8/11.025/12/16/22.05/24/32/44.1/48kHz (channel 0), 44.1kHz (channel 1) Output sampling rate: 44.1/48 kHz (channel 0), 8/16 kHz (channel 1) SD host interface SD memory I/O card interface (1-/4-bits SD bus) Error check function: CRC7 (command), CRC16 (data) Interrupt requests ⎯Card access interrupt ⎯SDIO access interrupt ⎯Card detect interrupt DMA transfer requests ⎯SD_BUF write ⎯SD_BUF read Card detect function, write protect supported Decompression unit Input data Data compressed with run-length encoding Output data RAW data General I/O ports SH7262: 89 I/Os, 6 inputs with open-drain outputs, and 4 inputs SH7264: 115 I/Os, 6 inputs with open-drain outputs, and 8 inputs Input or output can be selected for each bit A/D converter 10-bit resolution SH7262: four input channels, SH7264: eight input channels A/D conversion request by the external trigger or timer trigger Motor control PWM timer Two 10-bit PWM channels, each with eight outputs User debugging interface E10A emulator support JTAG-standard pin assignment On-chip RAM 64-Kbyte memory for high-speed operation (16 Kbytes 4) 1-Mbyte or 640-Kbyte large capacity memory for video display/recording and work (32-Kbytes for 1-Mbyte and 320-Kbytes for 640-Kbyte versions are used for data retention) 1-Mbyte version: 32-Kbyte memory for data retention (16 Kbytes 2) 640-Kbyte version: 320-Kbyte memory for data retention (16 Kbytes2, 128 Kbytes1, 160 Kbytes1) Boot modes Four boot modes Boot mode 0: Booting from memory connected to CS0 area Boot mode 1: Booting from a serial flash memory (high-speed communication) Boot mode 2: Booting from a NAND flash memory Boot mode 3: Booting from a serial flash memory (low-speed communication) Power supply voltage Vcc: 1.1 to 1.3 V Vcc: 3.0 to 3.6 V Packages SH7262 176-pin QFP, 24-mm square, 0.5-mm pitch JEITA package code: P-LQFP176-24 24-0.50 Renesas code: PLQP0176KB-A SH7264 208-pin QFP, 28-mm square, 0.5-mm pitch JEITA package code: P-LQFP208-28 28-0.50 Renesas code: PLQP0208KB-A SH7264主要应用: Audio: car audio, HDD audio and Network audio. Graphic dashboard, Vehicle information display. Industrial equipment: sequencer, robot etc. 图1.SH7264方框图 图2.SH7264入门板外形图 入门板主要指标: Item Specification Microcontroller R5S72643P144FPU On-board Memory Serial Flash (M25PX64): 64 Mbit NAND Flash (K9NBG08U5M-PCB0): 8 Gbit NOR Flash (S29GL512P-10T-AIR20): 512 Mbit SDRAM (IS42S16320B-7TL): 64 MB Input Clock Main: 18 MHz Sub: 32.768 kHz LCD: 25.175 MHz USB: 48 MHz Video Decoder: 24.576 MHz External DAC/ADC (for CODEC): 13 MHz Ethernet (for PHY): 25 MHz Potentiometer Single-turn, 10 kΩ LED 5 V Power indicator: blue x 1 3.3 V Power indicator: green x 1 User: yellow x 3 Switch Reset x 1 User x 16 DC Power Jack 5 V Input E10A-USB Header 14-pin box header RS232 Serial Connector 9-pin DSUB LCD Display Connector 14-pin socket TFT-LCD Panel Connector Hitatch 2.2' QVGA TFT: 39-pin (CN11) Generic LCD: 30-pin (JP12) USB Connector Socket-A & Mini-B CAN Connector 2.54 mm pitch, 3-pin (CAN Bus line x 2, Ground x 1) Ethernet Connector RJ45 SD Card Connector Reverse Type Audio Jack Headphone & Speaker Video Jack Compsite & Separate VGA Connector DB15H Microcontroller Pin Header 56-pin (JP15), 32-pin (JP16) 图3.SH7264入门板方框图 图4.SH7264入门板电路图(1) 图5.SH7264入门板电路图(2) 图6.SH7264入门板电路图(3) 图7.SH7264入门板电路图(4) 图8.SH7264入门板电路图(5) 图9.SH7264入门板电路图(6) 图10.SH7264入门板电路图(7) 图11.SH7264入门板电路图(8) 图12.SH7264入门板电路图(9) 图13.SH7264入门板电路图(10) 图14.SH7264入门板电路图(11) 图15.SH7264入门板电路图(12) 图16.SH7264入门板电路图(13) 图17.SH7264入门板主要元件布局图 音频DJ设备 DJ equipment is a device for playing back, mixing, and scratching music from CD and audio data as if they were from a vinyl record. DJ equipment is mainly made up of two DJ players and one DJ mixer. Although mainly used in North America and Europe until now, recently sales numbers of DJ equipment are increasing in emerging countries such as Russia and Brazil. In addition, although mostly used by businesses such as discos, due to the appearance of low-cost products private users are also increasing in number. Renesas Electronics simplifies the development of DJ equipment with SH726x 32-bit RISC microcontrollers with functions necessary for DJ equipment built-in and a lineup of motor drivers, power supply ICs, various standard ICs, opto-electronics devices, and so on. SH726x microcontrollers are built around the SH2A-FPU high-performance CPU core and integrate on-chip peripheral functions, such as an SD memory card interface, a NAND flash memory controller, USB, a CD-ROM decoder, and a serial sound interface. In addition, a variety of middleware products, such as an MP3 encoder/decoder, are available, allowing for flexible extension of functions and reducing the time required for system development. 图18.音频DJ设备系统方框图 详情请见: |
