Avago AEAT-6600-T16 16位可编程角度磁编码解决方案
发布时间:2011-10-9 15:37
发布者:Liming
Avago公司的 AEAT-6600是10- 16位可编程无接触磁旋转编码器,工作电压5V或3.3V,绝对值输出3线或2线SSI接口模式,绝对值10位到16位分辨率,增量输出分辨率8-1024CPR,主要用无刷DC马达的3相转子,替代电子分解器和电位计,工业自动化和机器人。本文介绍了AEAT-6600主要特性和指标,方框图以及OTP编程模式和对准模式电路图,AEAT-6600-T16磁编码器编程器套件主要特性: AEAT-6600-T16:10 to16-Bit Programmable Angular Magnetic Encoder IC The Avago AEAT-6600 angular magnetic encoder IC is a contact less magnetic rotary encoder for accurate angular measurement over a full turn of 360 degrees. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device. To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet may be placed above or below the IC. The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.005° = 65 536 positions per revolution. This digital data is available as a serial bit stream and as a PWM signal.An internal voltage regulator allows the AEAT-6600 to operate at either 3.3 V or 5 V supplies. AEAT-6600主要特性: 5 V or 3.3 V operation 3-wire or 2-wire SSI interface mode for absolute output Incremental ABI or UVW, and PWM output modes User-programmable zero position, direction & index pulse width Easy magnet alignment with magnetic field strength output and alignment mode ower-down mode to reduce current consumption TSSOP-16 IC package RoHS compliant AEAT-6600指标: Absolute 10-bits to 16-bits resolution Incremental output resolutions 8 to 1024 CPR -40℃ to 125℃ operating temperature range AEAT-6600应用: 3-phase commutation for brushless DC motor Resolver and potentiometer replacement Industrial automation and robotics 图1。AEAT-6600方框图 图2。AEAT-6600 OTP编程模式电路图 图3。AEAT-6600 对准模式电路图 图3。AEAT-6600-T16 PCB级 应用电路图 AEAT-6600-T16磁编码器编程器套件 This user manual describes the Avago HEDS-8937 programmer kit. The AEAT-6600-T16 magnetic encoder programming kit features real-time monitoring and programming of the 32-bit OTP memory within the AEAT-6600-T16 magnetic encoder IC. The HEDS-8937 kit includes the IC interface hardware that is supported by PC software. The IC interface hardware is a microcontroller system that links the AEAT-6600-T16 encoder to the PC through a USB cable. This user manual describes the hardware and PC software setup and gives instructions on PC software operation. AEAT-6600-T16磁编码器编程器套件主要特性: Bus-powered USB device On-board 6.5 V programming voltage Auto-power off when the AEAT-6600-T16 is removed from the programming socket Read and write the 32-bit OTP memory Real-time monitoring of SSI, PWM, ABI or UVW outputs Real-time monitoring of MAG_HI and MAG_LOW Signals 套件包括: 1. USB cable 2. AEAT-6600-T16 magnetic encoder programmer 3. IC adapter socket 4. 16-pin ribbon cable 5. Installation CD 图4。AEAT-6600-T16磁编码器编程器套件外形图 详情请见: |
