Connectone CO2144 10-100BaseT参考设计方案
发布时间:2011-8-23 12:34
发布者:Liming
Co2144 , Connectone
Connectone 公司的Co2144是全特性可编程的IP通信控制器,能用作协处理器从任何主控制器中卸载安全和IP连接任务,CO2128/CO2144固件支持多达10个同时作用的TCP/UDP 套接字(socket)和两个监听套接字,HTTP, SMTP, MIME, POP3, FTP 和TELNET客户,有两个网址的网络服务器,具有完整的互联网协议堆栈和RSA, AES-128/256, 3DES, RC-4, SHA-1, MD-5 与SSL3/TLS1加密,10/100BaseT 以太网MAC, USB 2.0全速主从器件,提供拨号,蜂窝,LAN和WiFi连接.本文介绍了CO2144主要特性,方框图,CO2144 主机和互联网环境以及10/100BaseT参考设计主要特性,电路图,方框图和材料清单。 iChip™ CO2064, CO2128 and CO2144 are full-featured programmable IP Communication Controller™ chips that act as coprocessors to offload security and IP connectivity tasks from any host processor. They are ideal for enabling devices to achieve secure, high-speed throughput and access to IP networks via 10/100BaseT LAN or 802.11b/g wireless LAN, and cellular or dial-up modems. Typically only one man-month is needed for hardware engineering and adding IP connectivity commands to the host application. While the CO2128/CO2144 include a complete set of features, the CO2064 uses an open software architecture that enables users to select and program different firmware flavors, each providing a unique subset of Internet protocols and features. The CO2128/CO2144 firmware supports up to 10 simultaneous active TCP/UDP sockets and two listening sockets; HTTP, SMTP, MIME, POP3, FTP and TELNET clients; a web server with two websites: one for configuring the CO2128/CO2144 and one for the application; and serial-to-IP bridging. The CO2064 comes in two firmware flavors: Flavor A offers 10 active TCP/UDP sockets and two listening sockets; sending ASCII e-mails; sending and retrieving data from an FTP server, and serial-to-IP bridging in SerialNet™mode. Flavor B supports one secure TCP/UDP socket plus 9 non-secure sockets. Security features in the CO2064 include the hardware implementation of a random number generator, SHA-1 secure hash accelerator, AES-128/256 encryption accelerator, 3DES, SSL3/TLS1, RSA, RC-4 and MD-5. The CO2128 includes, in addition to the above, WEP, WPA, and WPA2 encryption for WiFi. CO2064 loads its firmware and Internet configuration parameters either from an external SPI flash memory, or accepts it from the host via one of the supported interfaces. Firmware can be updated locally via RS232. CO2128/CO2144 load their firmware from an external EBI flash memory. Firmware can be remotely updated via sockets, FTP or HTTP. All three iChips include a 32-bit ARM7TDMI RISC processor and 256KB of embedded high-speed SRAM. Basic peripherals for all models include USB v. 2.0 full-speed host and device port; 10/100BaseT Ethernet MAC with MII/RMII, USART and SPI interfaces. Both CO2064 and CO2128/CO2144 feature Sleep mode for energy savings. The iChips come in a 64-pin (CO2064), 128-pin (CO2128) or 144-pin (CO2144) LQFP RoHS-compliant package. Key Features Complete Internet protocol stack RSA, AES-128/256, 3DES, RC-4, SHA-1, MD-5 and SSL3/TLS1 encryption 10/100BaseT Ethernet MAC USB v2.0 full-speed host and device USART, SPI interfaces CO2128/CO2144主要特性: Acts as a security gap between the host application and the network Provides dialup, cellular, LAN and WiFi connectivity Non-volatile, on-chip operational parameter database Up to 10 simultaneous TCP/UDP sockets and two listening sockets One secure SSL3/TLS1 socket Supports multiple Certificate Authorities and both client-side and server-side authentication Routing of IP packets between dialup/cellular and LAN/WiFi platforms using NAPT Supports infrasturcture and ad-hoc wireless LAN networks Enables roaming among Access Points sharing the same SSID Provides WEP, WPA and WPA2 wireless LAN security Includes a true hardware random number generator Triple DES, AES and SHA implemented in hardware Includes 10/100BaseT Ethernet MAC Sending and receiving textual email and binary email with MIME attachments HTTP client HTTP web server with two on-chip websites: configuration site and application site SerialNet mode for serial-to-IP bridging (port server mode) FTP and Telnet clients Secure FTP client (over SSL3) DHCP client and server RAS server Locally updateable firmware Remote configuration and firmware update over the Internet Retrieval of time data from a Network Time Server Performance Specifications Host Data Rate: Up to 3 Mbps in serial mode Serial Data Format (AT+i mode): Asynchronous character; binary; 8 data bits; no parity; 1 stop bit Serial Data Format (SerialNET mode): Asynchronous character; binary; 7 or 8 data bits; odd, even, or no parity; 1 stop bit Flow Control: Hardware (RTSH, CTSH, DCH) and software flow control Internet Protocols ARP, ICMP, IP, UDP, TCP, DHCP, DNS, NTP, SMTP, POP3, MIME, HTTP, FTP, Telnet Security protocols: SSL3/TLS1, HTTPS, FTPS, RSA, AES-128/256, 3DES, RC-4, SHA-1, MD-5, WEP, WPA and WPA2 Hardware Description CO2128 Size: 14.0 x 20.0 x 1.4 mm, 0.5mm pitch CO2064 Size: 10.0 x 10.0 x 1.4 mm, 0.5mm pitch CO2144 Size: 10.0 x 10.0 x 1.4 mm, 0.8mm pitch Core CPU: 32-bit RISC ARM7TDMI, low-leakage, 0.13 micron, running at 48MHz Operating Voltage: +3.3V+/-10% Operating Humidity: 90% maximum (non-condensing) Operating Temperature Range: -40° to 85°C (-40° to 185°F) Power Consumption with External VDD Core: 200mW (typical), Sleep Mode current: <2mA Host Interface: USART, USB host and USB device RoHS-compliant; lead-free 图1。CO2128/CO2144 方框图 图2。CO2128/CO2144 主机和互联网环境 10/100BaseT参考设计 iChip CO2144 with EBI Flash 10/100BaseT LAN and External Modem This Reference Design demonstrates the iChip™ CO2144 IP Controller™ connected to a host processor via USART, to a 2M flash memory chip via EBI interface, to a Wireless LAN module via SPI, and to an external modem via USART. Connect One’s AT+i™ commands are accepted at baud rates of up to 3Mbps. 10/100BaseT参考设计主要特性: Supports serial host interface speeds of up to 3Mbps (250K, 1M, 1.5M, 3M) SSL3/TLS1 security implemented in hardware provides better performance Data and Internet connection through Wi2Wi Wireless LAN Module based on the Marvell 88W8686 chipset, and any cellular or dial-up modem Operates at the industrial temperature range RoHS-compliant 图3。10/100BaseT参考设计方框图 图4。10/100BaseT参考设计电路图(1) 图5。10/100BaseT参考设计电路图(2) 图6。10/100BaseT参考设计电路图(3) 10/100BaseT参考设计材料清单: 详情请见: http://www.connectone.com/media/upload/CO2064_2128_2144_DataSheet.pdf 和 http://www.connectone.com/media/upload/RD162%20-%20CO2144_LAN_Ext_Modem_16_4430_21.pdf |
