AKM AK4627高性能四路24位音频CODEC解决方案
发布时间:2011-7-19 12:40
发布者:Liming
AKM公司的AK4627是高性能多路24位音频CODEC,具有四路ADC和六路DAC. 四路ADC有64x过取样,取样速率高达96kHz,S/(N+D)为92dB,动态范围单端为102dB,差分为103dB; 六路DAC有128x过取样,取样速率高达192kHz,24位8倍数字滤波器,S/(N+D)为90dB,动态范围为106dB,主要用在家庭影院和汽车音频设备等各种音频设备.本文介绍了AK4627主要特性,方框图, 典型应用电路图和评估板AKD4627-A主要功能,电路图和PCB布局图. The AK4627 is a single chip audio CODEC that includes four ADC channels and six DAC channels. The converters are designed with Enhanced Dual Bit architecture for the ADC’s, and Advanced Multi-Bit architecture for the DAC, enabling very low noise performance. The AK4627 ADC supports both single-ended and differential inputs and outputs. A wide range of applications can be realized, including home theater, pro audio and car audio. The AK4627 is available in a 48-pin LQFP package. AK4627主要特性: 4ch 24bit ADC - 64x Oversampling - Sampling Rate up to 96kHz - Linear Phase Digital Anti-Alias Filter - Single-ended / Differential Input - S/(N+D): 92dB (Single-ended, Differential) - Dynamic Range, S/N: 102dB (Single-ended), 103dB (Differential) - Digital HPF for offset cancellation - I/F format: MSB justified, I2S or TDM 6ch 24bit DAC - 128x Oversampling - Sampling Rate up to 192kHz - 24bit 8 times Digital Filter - Single-ended Outputs - On-chip Switched-Capacitor Filter - S/(N+D): 90dB - Dynamic Range, S/N: 106dB - I/F format: MSB justified, LSB justified(20bit,24bit), I2S or TDM - Individual channel digital volume with 128 levels and 0.5dB step - Soft mute - De-emphasis for 32kHz, 44.1kHz and 48kHz - Zero Detect Function High Jitter Tolerance TTL Level Digital I/F 3-wire Serial and I2C Bus μP I/F for mode setting Master clock: 256fs, 384fs or 512fs for fs=32kHz to 48kHz 128fs, 192fs or 256fs for fs=64kHz to 96kHz 128fs for fs=120kHz to 192kHz Power Supply: 4.5 to 5.5V Power Supply for output buffer: 2.7 to 5.5V Small 48pin LQFP 图1. AK4627方框图 图2. AK4627典型应用电路图 评估板AKD4627-A The AKD4627-A is an evaluation board for the AK4627, a single chip CODEC that includes four channels of ADC and six channels of DAC. The AKD4627-A also has the digital audio interface and can achieve the interface with digital audio systems via opt-connector or BNC connector. 评估板AKD4627-A主要功能: • On-board analog output buffer circuit • Compatible with 2 types of interface - AK4118 (DIT&DIR) with optical output/input and BNC output/input - Direct interface with AC3 decoder by 10pin header • 10pin header for serial control interface 图3.评估板AKD4627-A方框图 图4.评估板AKD4627-A电路图(1) 图5.评估板AKD4627-A电路图(2) 图6.评估板AKD4627-A电路图(3) 图7.评估板AKD4627-A电路图(4) 图8.评估板AKD4627-A电路图(5) 图9.评估板AKD4627-A电路图(6) 图10.评估板AKD4627-A电路图(7) 图11.评估板AKD4627-A元件布局图 详情请见: http://www.asahi-kasei.co.jp/akm/en/product/ak4627/ak4627_f00e.pdf 和 http://www.asahi-kasei.co.jp/akm/en/product/ak4627/akd4627-a0-00e.pdf |
