IR IRS2092 1700W单路D类音频功率放大方案
发布时间:2011-6-1 10:45
发布者:Liming
IR公司的 IRS2092是集成了PWM调制器和保护的高压高性能D类音频放大器,工作频率高达800kHz,±100 V额定电压是可提供500W输出功率,主要用在家庭影院,密你立体声系统,通用音频放大器等。本文介绍IRS2092主要特性,方框图,典型连接图,典型应用电路图以及1700W单路D类音频功率放大器框图,主要特性,电路图和材料清单。 The IRS2092 is a high voltage, high performance Class D audio amplifier driver with PWM modulator and protection. In conjunction with two external MOSFET and a few external components, a complete Class D audio amplifier with protection can be realized. International Rectifier’s proprietary noise isolation technology allows high current gate drive stage and high speed low noise error amplifier reside on a single small silicon die.Open elements of PWM modulator section allow flexible PWM topology implementation. IRS2092主要特性: • Integrated analog input Class D audio amplifier driver in a small 16 pin package • Floating inputs enable easy half bridge implementation • Programmable bidirectional over-current protection with self-reset function • Programmable preset deadtime for improved THD performances • Start and stop click noise reduction • High noise immunity • ±100 V ratings deliver up to 500 W in output power • Operates up to 800 kHz • RoHS compliant IRS2092典型应用: • Home theater systems • Mini component stereo systems • Powered speaker systems • General purpose audio power amplifiers 图1。IRS2092方框图 图2。IRS2092典型连接图 图3。IRS2092典型应用电路图 1700W单路D类音频功率放大器 IRAUDAMP9:1.7 kW / 2-Ω Single Channel Class D Audio Power Amplifier Using the IRS2092S and IRFB4227 The IRAUDAMP9 reference design is a single-channel 1.7-kW ( @ 2Ω load) half-bridge Class D audio power amplifier. This reference design demonstrates how to use the IRS2092S Class D audio controller and external gate buffer, to implement protection circuits, and design an optimum PCB layout using the IRFB4227 (x 2 Pairs) TO-220 MOSFETs. This reference design may require additional heatsink or fan for normal operation (one-eighth of continuous rated power). The reference design provides all the required housekeeping power supplies for ease of use. The 1-channel design is capable of delivering higher than its rated power with provision of larger heat sink ( Rth <2° C / W). 1700W单路D类音频功率放大器主要应用: • Pro-Audio amplifiers • Powered speakers • Active Sub-woofers • P.A. Systems • Car audio amplifiers Musical Instrument amplifier 1700W单路D类音频功率放大器主要特性: Output Power: 1.7 kW Single channel (2 Ω load, 1kHz, THD+N=10%), Residual Noise: 290μV, IHF-A weighted, AES-17 filter Distortion: 0.07% THD+N @ 600W, 2Ω Efficiency: 97% @ 1.7 kW, 2Ω Multiple Protection Features: Output Over-current protection (OCP), high side and low side Input Over-voltage protection (OVP), Input Under-voltage protection (UVP), Output DC-offset protection (DCP), Over-temperature protection (OTP) PWM Modulator: Self-oscillating half-bridge topology with optional clock synchronization 图4。1700W单路D类音频功率放大器功能方框图 图5。1700W单路D类音频功率放大器外形图 图5。IRS2092S保护电路功能框图 图6。1700W单路D类音频功率放大器测试图 图7。1700W单路D类音频功率放大器电路框图 图8。1700W单路D类音频功率放大器电路图(1) 图9。1700W单路D类音频功率放大器主板输入/输出电源连接图 图10。1700W单路D类音频功率放大器主板电路图(1) 图9。1700W单路D类音频功率放大器子板电路图 IRAUDAMP9主板材料清单: IRAUDAMP9子板材料清单: IRAUDAMP9机械零件清单: 详情请见: http://www.irf.com/product-info/datasheets/data/irs2092.pdf 和 http://www.irf.com/technical-info/refdesigns/iraudamp9.pdf |
