http://item.taobao.com/auction/i ... htm?cm_cat=50002918
Diagonal Screen Size 0.96”
Part Number UG-2864AMBAG01
Number of Pixels 128x64
Color Depth Area Color(Light BIue,Yellow)
Module Construction COG
Module Size (mm) 26.70 x 29.06 x 2.00
Panel Size (mm) 26.70 x 19.26 x 1.45
Active Area (mm) 21.74 x 11.20
Pixel Pitch (mm) 0.17 x 0.17
Pixel Size (mm) 0.15 x 0.15
Weight (g) 1.54
Duty 1/64
Brightness(cd/m2) 80 (Typ)@9V
Interface Parallel,4-wire SPI
Assembly Soldering/Hot Bar
Part Number UG-2864HSWEG01
Color Depth Monochrome(White)
Module Size (mm) 26.70 x 31.26 x 1.45
Active Area (mm) 21.744 x 10.864
Pixel Size (mm) 0.154 x 0.154
Weight (g) 1.54
Duty 1/64
Interface Parallel,3-/4-wire SPI,IIC,
Assembly Soldering/Hot Bar |
