Algoltek安格科技主要提供各种格式的视频转换的整体解决方案,例如MHL, HDMI,VGA,DisplayPort,Type-C ALT模式,广泛应用于在设备和信源设备之间切换/分离视频信号的ASIC解决方案,安格瑞科技代理ALGO LTEK产品,提供全程技术资料。 Algoltek安格产品线选型表如下:
| | | | | | | | Product P/N | | Product Description/ Resolution | | | | | AG6111 | | ※ Compliant to MHL2.2 and HDMI1.4b | | | | | ※ Resolution and Frame Rate: | | | | | | - 3D as 1080p 30 frames in Packed pixel mode | | | AG6200 | | ※ Compliant to HDMI1.4b and VESA VSISTM V1.2 Standard | | | | | ※ VGA Resolution: 1920X1200@60Hz | | | AG7110 | | | | | | | | | | ※ Resolution and Frame Rate: | | | - Support 340 MHz pixel clocks | | | - Compatible with 36-bit deep color | | | AG7111 | | | | | | | | | | ※ Resolution and Frame Rate: | | | - Support 340 MHz pixel clocks | | | - Compatible with 36-bit deep color | | | AG7120 | | | | | | | ※ Resolution and Frame Rate: | | | - Support 340 MHz pixel clocks | | | - Support 4K2K@30Hz, compatible with 36-bit deep color | | | AG6300 | | | | | | | ※ External SPI flash supported for firmware upgrade | | | ※ Down Spread Spectrum Clock (SSC) supported | | | ※ On-chip HDCP1.4 Key Integrated | | | ※ Support I2S stereo audio interface | | | AG6310 | | | | | | | ※ External SPI flash supported for firmware upgrade | | | ※ Down Spread Spectrum Clock (SSC) supported | | | ※ On-chip HDCP1.4 Key Integrated | | | ※ Support I2S stereo audio interface | | | AG6320 | | | | | | | ※ External SPI flash supported for firmware upgrade | | | ※ Down Spread Spectrum Clock (SSC) supported | | | ※ On-chip HDCP1.4 Key Integrated | | | ※ Support I2S stereo audio interface | | | AG9300 | USB Type-C to VGA Converter | ※ Type-C DP ALT mode supported | | | | | | | | ※ External SPI flash supported for firmware upgrade | | | ※ Down Spread Spectrum Clock (SSC) supported | | | ※ On-chip HDCP1.4 Key Integrated | | | ※ Support I2S stereo audio interface | | | AG9310 | USB Type-C to HDMI Converter | ※ Type-C DP ALT mode supported | | | | | | | | ※ External SPI flash supported for firmware upgrade | | | ※ Down Spread Spectrum Clock (SSC) supported | | | ※ On-chip HDCP1.4 Key Integrated | | | ※ Support I2S stereo audio interface | | | AG9320 | USB Type-C to HDMI/VGA Converter | ※ Type-C DP ALT mode supported | | | | | | | | ※ External SPI flash supported for firmware upgrade | | | ※ Down Spread Spectrum Clock (SSC) supported | | | ※ On-chip HDCP1.4 Key Integrated | | | ※ Support I2S stereo audio interface | | | | | | | | |
