imx6 , 明远智睿 , 核心板 , 开发板 , 嵌入式
【接上一章节明远智睿IMX6ULL启动和烧写(3)】
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 9a b0 96 db 55 9c e5 b6
platform caam_sm: [0008] 9a 1c 66 fe 4b 9f a3 a4
platform caam_sm: [0016] f7 e4 32 59 f9 54 d8 ae
platform caam_sm: [0024] e9 a3 93 3e 11 1f 67 f6
platform caam_sm: [0032] 12 a9 75 a5 5a 66 98 91
platform caam_sm: [0040] 5b a7 45 2d 51 fc ee fa
platform caam_sm: [0048] b7 52 23 75 94 5e bb 44
platform caam_sm: [0056] c7 2e 6c 42 d0 80 eb d8
platform caam_sm: [0064] 42 d3 91 db 37 6c 23 1b
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] af 7a 91 4c 4b 00 7a 08
platform caam_sm: [0008] a8 61 b2 99 ff bc 31 e8
platform caam_sm: [0016] 22 e7 ce 1b 10 aa d6 12
platform caam_sm: [0024] 8e 9e fa ef 49 e8 da 72
platform caam_sm: [0032] 21 40 d0 1a b7 dc 56 64
platform caam_sm: [0040] e3 57 2c 28 32 fd 0e 15
platform caam_sm: [0048] 26 1a 65 74 c4 91 52 ca
platform caam_sm: [0056] b2 61 03 22 4e 4f ce 6f
platform caam_sm: [0064] 16 f5 db 23 5d d6 eb 6e
platform caam_sm: [0072] 4b 84 28 07 e0 89 83 7f
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 63 38 5c da 32 ec a9 17
platform caam_sm: [0008] 5c 13 91 ba 4c 7a f3 b2
platform caam_sm: restored 128-bit black key:
platform caam_sm: [0000] d1 93 16 c8 3c cf 31 ee
platform caam_sm: [0008] 39 7d 9f 34 fe 18 10 ae
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0000] 9d 1a df 99 81 a9 93 be
platform caam_sm: [0008] 4d 06 7b 6b b9 c1 7b f9
platform caam_sm: [0016] 90 42 db ed cf 86 4e 15
platform caam_sm: [0024] 6b 9d a0 4b 3a 3a 23 28
platform caam_sm: restored 256-bit black key:
platform caam_sm: [0000] 6e 08 25 76 e8 b4 ed af
platform caam_sm: [0008] f6 cf 42 04 f3 3e 0a 81
platform caam_sm: [0016] 58 3b f5 b2 83 dd 4c c9
platform caam_sm: [0024] 1b 28 66 89 59 46 e7 be
bFWReady == _FALSE call reset 8051…
caam-snvs 20cc000.caam-snvs: can’t get snvs clock
caam-snvs 20cc000.caam-snvs: violation handlers armed - non-secure state
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
2198000.adc supply vref not found, using dummy regulator
imx-wm8960 sound: wm8960-hifi <-> 202c000.sai mapping ok
imx-wm8960 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
NET: Registered protocol family 26
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
lib80211: common routines for IEEE802.11 drivers
Key type dns_resolver registered
cpu cpu0: Registered imx6q-cpufreq
imx_thermal 2000000.aips-bus:tempmon: Commercial CPU temperature grade - max:95C critical:90C passive:85C
dhd_module_init in
rtc-isl1208 0-006f: hctosys: unable to read the hardware clock
ALSA device list:
#0: wm8960-audio
EXT4-fs (mmcblk1p2): couldn’t mount as ext3 due to feature incompatibilities
EXT4-fs (mmcblk1p2): 1 orphan inode deleted
EXT4-fs (mmcblk1p2): recovery complete
EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 1024K
INIT: version 2.88 booting
Starting udev
udevd[215]: starting version 3.1.5
EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
bootlogd: cannot allocate pseudo tty: No such file or directory
FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
ALSA: Restoring mixer settings…
Found hardware: “wm8960-audio” “” “” “” “”
Hardware is initialized using a generic method
hwclock: RTC_RD_TIME: Invalid argument
Fri Sep 21 22:02:00 UTC 2018
INIT: Entering runlevel: 5
Configuring network interfaces… SMSC LAN8710/LAN8720 20b4000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=20b4000.ethernet-1:00, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting Xserver
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting rpcbind daemon…done.
starting statd: done
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting atd: OK
exportfs: can’t open /etc/exports for reading
NFS daemon support not enabled in kernel
Starting system log daemon…0
Starting kernel log daemon…0
Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon [ ok ]
Starting Telephony daemon
Starting Linux NFC daemon
Starting crond: OK
*** Welcome to i.MX6 ***************************************
Rootfs File: L4115-fsl-image-qt5-myimx6a7.tar.bz2
Build Time: 20180921193618
Config Time: svn126 2018-12-21 14:02:36.681988900 +0800
IP Address: 192.168.137.81
1.SITE: www.myzr.com.cn
2.WIKI: wiki.myzr.com.cn
3.BBS: bbs.myzr.com.cn
Running local boot scripts (/etc/rc.local).
Freescale i.MX Release Distro 4.1.15-2.1.0 myimx6ek140p /dev/ttymxc0
烧写
a.设置拨码开关
BOOTMODE设置启动模式: 1(ON),2(OFF)
BOOT_CFG 设置存储为EMMC: 1(ON),2(ON),3(ON),4(OFF)
b.插上调试串口和micro usb线和串口工具配置
直接用USB转串口线接到RS232/DEBUG的DB9座子,另一端接到电脑;插上micro usb线到座子USB OTG上,配置SecureCRT。
c.开机和烧写
插上5V电源适配器到座子5V_IN,打开SWITCH,板子开机。配置烧写工具MfgConfig.exe,
MY-IMX6-CB140P-6Y2D-256M-4G,如下图:(6Y2D是IMX6ULL,256M是内存,4G是EMMC)
配置如下:
点击Make生成配置文件,打开MfgTool2.exe
点击Start开始烧写和点击Stop完成。
