imx6 , 明远智睿 , 核心板 , 开发板 , 嵌入式
明远智睿R16 tinav2.1 常见问题参考手册
1 R16 tinav2.1常见问题
1.1 分区
修改target/allwinner/astar-parrot/configs/sys_partition.fex
例如:
[partition]
name = rootfs_data
size = 12582912
user_type = 0x8000
修改其中的size属性,单位: 扇区。
如要修改成1G,计算方法如下
size = 1024 * 1024 * 1024 / 512
1.2 把文件打包到rootfs
将文件放到package/base-files/files目录下即可。如果文件过大,在pack时报错,修改分区表的rootfs分区的大小
1.3 增加spi
1) 在内核中添加spi 驱动
$cd tinaV2.1
$source build/envsetup.sh
$lunch astar_parrot-tina
$make kernel_menuconfig
Device Drivers --->
SPI support --->
<*> User mode SPI device driver support
2) 修改
tinaV2.1/target/allwinner/astar-parrot/configs/sys_config.fex
[spi_board0]
modalias = "at25df641"
sflash_size = 32
max_speed_hz = 50000000
bus_num = 0
chip_select = 0
mode = 0
修改成
[spi_board0]
modalias = "spidev"
sflash_size = 32
bus_num = 0
chip_select = 0
mode = 0
1.4 以太网不可用
$cd tinaV2.1
Device Drivers --->
Network device support --->
USB Network Adapters --->
<*> Multi-purpose USB Networking Frameworksuch as cable modems)
<*> SMSC LAN95XX based USB 2.0 10/100 ethernet devices
