PCB设计中专业英译术语之综合词汇
发布时间:2018-4-27 09:34
发布者:板儿妹0517
1. 板:board 2. 印制板:printed board 3. 印制电路:printed circuit 4. 印制线路:printed wiring 5. 印制线路板:printed wiring board(PWB) 6. 印制板电路:printed circuit board (PCB) 7. 印制接点:printed contact 8. 印制组件:printed component 9. 印制板装配:printed board assembly 10. 单面印制板:single-sided printed board(SSB) 11. 双面印制板:double-sided printed board(DSB) 12. 多层印制板:mulitlayer printed board(MLB) 13. 多层印制电路板:mulitlayer printed circuit board 14. 多层印制线路板:mulitlayer prited wiring board 15. 刚性印制板:rigid printed board 16. 刚性单面印制板:rigid single-sided printed borad 17. 刚性双面印制印制板装配:printed board assembly 18. 刚性多层印制板:rigid multilayer printed board 19. 挠性多层印制板:flexible multilayer printed board 20. 挠性印制板:flexible printed board 21. 挠性单面印制板:flexible single-sided printed board 22. 挠性双面印制板:flexible double-sided printed board 23. 挠性印制电路:flexible printed circuit (FPC) 24. 挠性印制线路:flexible printed wiring 25. 刚性印制板:flex-rigid printed board, rigid-flex printed board 26. 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed 27. 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board 28. 齐平印制板:flush printed board 29. 金属芯印制板:metal core printed board 30. 金属基印制板:metal base printed board 31. 多重布线印制板:mulit-wiring printed board 32. 陶瓷印制板:ceramic substrate printed board 33. 导电胶印制板:electroconductive paste printed board 34. 模塑电路板:molded circuit board 35. 模压印制板:stamped printed wiring board 36. 顺序层压多层印制板:sequentially-laminated mulitlayer 37. 散线印制板:discrete wiring board 38. 微线印制板:micro wire board 39. 积层印制板:buile-up printed board 40. 积层多层印制板:build-up mulitlayer printed board (BUM) 41. 积层挠印制板:build-up flexible printed board 42. 表面层合电路板:surface laminar circuit (SLC) 43. 埋入凸块连印制板:B2it printed board 44. 多层膜基板:multi-layered film substrate(MFS) 45. 层间全内导通多层印制板:ALIVH multilayer printed board 46. 载芯片板:chip on board (COB) 47. 埋电阻板:buried resistance board 48. 母板:mother board 49. 子板:daughter board 50. 背板:backplane 51. 裸板:bare board 52. 键盘板夹心板:copper-invar-copper board 53. 动态挠性板:dynamic flex board 54. 静态挠性板:static flex board 55. 可断拼板:break-away planel 56. 电缆:cable 57. 挠性扁平电缆:flexible flat cable (FFC) 58. 薄膜开关:membrane switch 59. 混合电路:hybrid circuit 60. 厚膜:thick film 61. 厚膜电路:thick film circuit 62. 薄膜:thin film 63. 薄膜混合电路:thin film hybrid circuit 64. 互连:interconnection 65. 导线:conductor trace line 66. 齐平导线:flush conductor 67. 传输线:transmission line 68. 跨交:crossover 69. 板边插头:edge-board contact 70. 增强板:stiffener 71. 基底:substrate 72. 基板面:real estate 73. 导线面:conductor side 74. 组件面:component side 75. 焊接面:solder side 76. 印制:printing 77. 网格:grid 78. 图形:pattern 79. 导电图形:conductive pattern 80. 非导电图形:non-conductive pattern 81. 字符:legend 82. 标志:mark 以上即是PCB设计中专业英译术语之综合词汇,下期预告:PCB设计中专业英译术语之基材,更多更多行业信息可查阅快点学院订阅号:eqpcb_cp。 |
