手机、触控玻璃强化表面应力仪
发布时间:2017-12-21 16:10
发布者:ptc0426
Tel:0512-57005538 18913228856 SURFACE STRESS METER FOR TEMPERED GLASS(REF.ASM-100-3) The Surface Stress Meter is designed for measuring compression stress of tempered glass.It makes the light spread along the surface of glass and then the value of surface stress and depth will be tested through photoelastic principle.Computer equipped will be used to reduce measurement error caused by operator and also be available for data management.In addition,automatic titrator and thickness gauge are in option to achieve efficiency improvement. FEATURES ① peculiar Measurement Principle-Photoelastic Analysis Refractormeter ② automated testing reducing errors caused by operators ③ computer to save data for quality control ④ manual testing available when samples are not in good tempered condition ⑤ LED lamp with 10000 hours serving time ⑥ Master Piece to achieve system self-calibration. ⑦ automated determination of qualified or unqualified according to operators’ setting while continuous testing in progress ⑧ data saved and testing times displayed immediately while continuous testing in progress ⑨ single and manual measurement in option ⑩ automated Immersion Drop Function controlled by specific software to reduce Immersion liquid cost SPECIFICATIONS Stress Measurement Range(Mpa): 1-1000 Stress Measurement Accuracy(Mpa): ±20 Depth Measurement Range(μm): 0-200 Depth Measurement Accuracy(μm): ±5μm Measurement Object: chemically and physically tempered glass Measurement area(mm): ≥12*7 Measurement principle: Photoelastic Analysis by Refractormeter Source of Light: special LED(with wavelength 590nm±10) IR of Prism: 1.72 PC: special OS & software(installed) Software: special software ASM-100-3 Power: AC220V 3A Air Source(Mpa): 1(clean air) Weight(Measuring Head)(Kg): about 14 LIST ① Measuring Head: 1 set (ASM-100-3) ② Prism(12*7mm): 1 set (installed on Measuring Head) ③ Computer(DELL): 1 set ④ Dongle: 1 set (inserted in computer) ⑤ ASM Measurement software: 1 set (installed on computer) ⑥ Immersion Liquid: 20ml ⑦ Master Piece: 1 set ⑧ XP OS ⑨ Manual: 1 set in Chinese Version ⑩ Liquid Titrition: 1 set 化学强化玻璃表面应力仪ASM-100-3 技术规格书 ASM-100-3应力仪通过让光沿着玻璃表面传播,根据光弹性技术测量化学强化玻璃的表面应力以及应力层深度。本机带有电脑,能够减少测量者的误差也更便于测量数据的管理,用户可自行额外付费选配自动滴液和测厚的配置来全面提高测量效率。 一、特点: 1.具有先进的无损检测方法(折射计光弹性分析原理)。 2.自动测量,因测试者造成的个人误差小。 3.能够用电脑自动保存数据,便于品质管理。 4.测试条件不佳的试料可以进行手动测量。 5.使用LED光源,使用寿命长,达到10,000小时。 6.使用了玻璃校准片因此可将机器误差控制到最小。 该款机器的特色描述: 1、实现连续测量的同时并根据设置区间自动判断合格/不合格。 2、在连续测量时系统自动保存测量的数据,并累计测量数目(合格数目/不合格数目)。 3、除了连续测量,也可以自由选择单次测量、手动测量等测量方式。 4、实现软件控制自动滴液功能(节约人工操作带来液体的浪费)(额外付费选配功能)。 5、配备测厚装置,软件自动测量样品厚度(额外付费选配功能)。 二、设备规格: 测量范围(应力):0-1000Mpa 测量精度(应力):±20MPa 测量范围(应力层深度):0-200μm 测量精度(应力层深度):±5μm 测量对象:化学强化玻璃 测量形状:平板玻璃 12*7mm 或以上 测量原理:折射计光弹性分析原理 光源:专用LED 波长590nm ±10nm 棱镜: ND=1.72 PC:专用(OS、测量软件 已安装) 分析软件:ASM-100-3特制软件 电源:AC220V 3A 尺寸(测量头):300×600×250MM 重量(测量头): 大约14KG 三、配置清单 1、ASM-100-3测量头:1套 2、12mm*7mm的特制棱镜:1枚(已安装在ASM-100-3测量头上) 3、CCD摄像系统:1套(已安装在ASM-100-3测量头上) 4、台式电脑:1台,DELL 5、软件狗:1个(在主机上) 6、ASM测量软件:1套(中文,已安装在电脑上) 7、测量液体:1包(20ml) 8、玻璃校准片: 1块 9、XP/WIN7 中文操作系统(已安装在电脑中) 10、使用手册:中文1份 11、滴液装置及组件:1套(额外付费选配) 12、PLT-0025测厚装及组件:1套(额外付费选配) |
