利用串口调试精灵或PC的超级终端调试串口的程序
发布时间:2010-11-5 19:29
发布者:techshare
;利用串口调试精灵或PC端的超级终端,波特率设为9600,数据位8位, ;停止位1位,无校验位. ;首选从PC机向串串口发送一个字符如"2",单片机收到后返发收到这个数如"2-PIC16"给电脑. ;注意实验板的设定:S4,S5,S1要全部到OFF,S13第6,7脚一定要ON. ;烧写时注意振荡方式XT,WDT要禁止. LIST P=16F877 INCLUDE "P16F877.INC" ;*********************************** __CONFIG _DEBUG_OFF&_CP_ALL&_WRT_HALF&_CPD_ ON&_LVP_OFF&_BODEN_OFF&_PWRTE_ON&_WDT_OFF&_HS_OSC; ;************************ CBLOCK 0x20 TXBUFF :9 TXPTR TXCOUNT RXBUFF :9 PUTPTR GETPTR STATUS_TEMP FSR_TEMP ENDC W_TEMP EQU 7FH ;------------------------- ORG 0X000 GOTO MAIN ;------------------------- ORG 0X004 GOTO INT ORG 0X008 INT MOVWF W_TEMP SWAPF STATUS,W CLRF STATUS MOVWF STATUS_TEMP MOVFW FSR MOVWF FSR_TEMP CHKRXINT BANKSEL PIR1 BTFSS PIR1,RCIF GOTO CHKTXINT _RDRXFIFO BTFSC RCSTA,FERR GOTO _FERR_PRO MOVLW RXBUFF MOVWF FSR MOVF PUTPTR,W ADDWF FSR,F MOVF RCREG,W MOVWF INDF INCF PUTPTR,F MOVLW .7 ANDWF PUTPTR,F BTFSC PIR1,RCIF GOTO _RDRXFIFO BTFSS RCSTA,OERR GOTO ENDOFINT _OERR_PRO BCF RCSTA,CREN BSF RCSTA,CREN GOTO ENDOFINT _FERR_PRO MOVF RCREG,W GOTO ENDOFINT ;------------------------ CHKTXINT BSF STATUS,RP0 BTFSS PIE1,TXIE GOTO ENDOFINT BCF STATUS,RP0 BTFSS PIR1,TXIF GOTO ENDOFINT MOVLW TXBUFF MOVWF FSR MOVF TXPTR,W ADDWF FSR,F MOVF INDF,W MOVWF TXREG INCF TXPTR,F DECFSZ TXCOUNT,F GOTO ENDOFINT BSF STATUS,RP0 BCF PIE1,TXIE BCF STATUS,RP0 ENDOFINT CLRF STATUS MOVFW FSR_TEMP MOVWF FSR SWAPF STATUS_TEMP,W MOVWF STATUS SWAPF W_TEMP,F SWAPF W_TEMP,W RETFIE ;------------------- MAIN BANKSEL TXSTA MOVLW B'00100100' MOVWF TXSTA MOVLW .25 MOVWF SPBRG CLRF PIE1 BSF PIE1,RCIE CLRF STATUS CLRF TXCOUNT CLRF GETPTR CLRF PUTPTR MOVLW B'10010000' MOVWF RCSTA CLRF INTCON BSF INTCON,PEIE BSF INTCON,GIE LOOP CALL CHECK_DATA GOTO LOOP ;------------------------- CHECK_DATA CLRF STATUS MOVF TXCOUNT,W SKPZ RETURN MOVF GETPTR,W XORWF PUTPTR,W SKPNZ RETURN MOVLW RXBUFF MOVWF FSR MOVF GETPTR,W ADDWF FSR,F INCF GETPTR,F MOVLW .7 ANDWF GETPTR,F MOVF INDF,W MOVWF TXBUFF+0 MOVLW 'P' MOVWF TXBUFF+1 MOVLW 'I' MOVWF TXBUFF+2 MOVLW 'C' MOVWF TXBUFF+3 MOVLW 'A' MOVWF TXBUFF+4 MOVLW 'V' MOVWF TXBUFF+5 MOVLW 'R' MOVWF TXBUFF+6 MOVLW 0X0D MOVWF TXBUFF+7 MOVLW 0X0A MOVWF TXBUFF+8 MOVLW .9 MOVWF TXCOUNT CLRF TXPTR BSF STATUS,RP0 BSF PIE1,TXIE BCF STATUS,RP0 RETURN ;--------------------- END |
