上海后端好职位(实习生,应届生,engineer和leader)
公司招聘,后端好职位不要错过。如果有意向可将简历发到hr@magic-semi.com 1. 实习生职位 Magic-semi JD forIntern Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way. RESPONSIBILITES: 1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute. 2. Work with Front-end designers to optimizetiming/area/power of the design implementation and perform static timinganalysis. 3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS). 4. Static Timing analysis (Prime Time or ETS)and setup/hold fix.
Requirements: 1.CS/EE or background in areas related todigital or analog chip design 2.Known of IC backend flow. 3.Known of timing concept. 4.Have reading and writing skills forenglish 5.Experience in floorplan, place, cts,route, timing ,pv and power analysis and so on. 6.Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 7.Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 8.Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 9.Good analytical and debugging skills. Send your CV to hr@magic-semi.com if you are interested. 2.应届生 Magic-semi JD for NCG Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way. Job Title: Intern/NCG RESPONSIBILITES: 1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute. 2. Work with Front-end designers to optimize timing/area/powerof the design implementation and perform static timing analysis. 3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS). 4. Static Timing analysis (Prime Time or ETS)and setup/hold fix.
Requirements: 1.CS/EE or background in areas related todigital or analog chip design 2.Be familiar with IC backend flow. 3.Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 4.Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 5.Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 6.Good analytical and debugging skills. Send your CV to hr@magic-semi.com if you are interested. 3. 高级工程师 Magic-semi JD forSenior Engineer Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way. Job Title: Senior Engineer RESPONSIBILITES: 1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute. 2. Work with Front-end designers to optimize timing/area/powerof the design implementation and perform static timing analysis. 3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS). 4. Static Timing analysis (Prime Time or ETS)and setup/hold fix.
Requirements: 1.CS/EE or background in areas related todigital or analog chip design 2.3 year+ work experience. 3.experience in floorplan, place, cts,route, timing ,pv and power analysis and so on. 4.Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 5.Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 6.Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 7.Good analytical and debugging skills. Send your CV to hr@magic-semi.com if you are interested. 4. leader Magic-semi JD forLeader Engineer Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII. Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way. Job Title: Leader Engineer RESPONSIBILITES: 1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute. 2. Work with Front-end designers to optimize timing/area/powerof the design implementation and perform static timing analysis. 3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS). 4. Static Timing analysis (Prime Time or ETS)and setup/hold fix.
Requirements: 1.CS/EE or background in areas related todigital or analog chip design 2.7 year+ work experience for IC backend. 3.Experience in floorplan, place, cts,route, timing ,pv and power analysis and so on. 4.Have experience for project management. 5.Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus. 6.Experience with one or more scripting languages (Perl, TCL, or Shell) to make reusable automatically flow is a plus. 7.Experience and knowledge about FE design(RTL code, flow) and verification is a plus. 8.Good analytical and debugging skills. 9.Self-motivated and good team player. Send your CV to hr@magic-semi.com if you are interested. |
