Fairchild USB Type-C Portfolio
Fairchild USB Type-C Portfolio sets the convenience and simplicity standard for users, designers and manufacturers. It's optimized for cost, footprint and low-power use with a complete portfolio of discrete, flexible USB Type-C solutions from controllers to power switches and SuperSpeed switches. Power consumption is 1/10 of the nearest competitive solution and packages are up to 43% smaller.
Features
Ultra-low-power consumption in standby mode
Flexible to accommodate standard changes
DFP, UFP, DRP role support
Active cable detection and power support
Small solutions in WLCSP and MLP packages, as small as 1.2x1.2x0.4mm
Thin USB Power Delivery (PD) interface for adaptive charging and vendor-defined messages
Audio and Debug Accessory Detection
View Product List
Block Diagram
ControllersPart Number | Function | Mode | Standby Current typ (μA) | Standby Current typ (nA) | Package/Dimensions
(mm) | Additional Resources | | Programmable controller | DFP, UFP, DRP, accessory support | 20 | 2200 | WLCSP-9/1.2x1.2x0.4 | | FUSB301
| Autonomous controller with SuperSpeed switch control | DFP, UFP, DRP, accessory support | 5 | 3.5 | TMLP-10/1.6x1.2x0.4
| | FUSB301A
| Autonomous controller with configurable I2C address | DFP, UFP, DRP, accessory support | 5 | 3.5 | TMLP-12/1.6x1.6x0.4
| | | Programmable controller with PD | DFP, UFP, DRP, accessory support | 25 | 370 | WLCSP-9, MLP-14/1.2x1.3x0.6, 2.5x2.5x0.8
| | FUSB3301
| Autonomous power adapter controller | DFP | 10 | — | MLP-10/3x3x0.8
| Data SwitchesPart Number | Function | Data Rate | Insertion Loss | Active Current (μA) | Package/Dimensions
(mm) | Additional Resources | | USB 3.1 SuperSpeed switch | Up to 10Gbps
| -1.0dB at 2.5GHz | 12 | MLP-18/2x2.8x0.4 | |
| Protection ICsPart Number | Function | DC Current (A) | RDSON (mΩ) | Features | Package/Dimensions
(mm) | Additional Resources | | Over-voltage protection load switch | 4.5 | 33 | Selectable OVP, 100V surge | WLCSP-12/1.2x1.6x0.6 | | | Bi-directional load switch | 6 | 10 | RCB protection, slew rate control | WLCSP-12/1.2x1.6x0.6 | | | VCONN protection | 4.5 | 33 | Over-voltage, over-current protection | WLCSP-9/1.2x1.2x0.6 | |
