查看: 11124|回复: 0
[提问] 飞思卡尔16位单片机
发表于 2015-10-28 10:22:25 | 显示全部楼层 |阅读模式
关键词: CW5.1 , MC9S12XET
   MCU clock speed: 4000000 Hz
Block Module Name      Address Range   Status
   0  PFLASH            4000 -  7FFF   Programmed - Unselected
   1  PFLASH            C000 -  FFFF   Programmed - Unselected
   2  PFLASH          E08000 -E7BFFF   Programmed - Unselected
   3  PFLASH          F88000 -FFBFFF   Programmed - Unselected
   4  DFLASH             800 -1F0BFF   Programmed - Unselected
FP: The UNPROTECT command is not available for the PFLASH flash module => Skipped.
FP: The UNPROTECT command is not available for the DFLASH flash module => Skipped.
executing .\cmd\TBDML_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\TBDML_vppon.cmd
Vppon command file correctly executed.
FP: Operation failed on PFLASH flash module.
FP: Operation failed on DFLASH flash module.
executing .\cmd\TBDML_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\TBDML_vppoff.cmd
Vppoff command file correctly executed.
FP: Arm FLASH for loading.
FP: FLASH disarmed.
executing .\cmd\TBDML_reset.cmd
!// After reset the commands written below will be executed
done .\cmd\TBDML_reset.cmd
Reset command file correctly executed.
executing .\cmd\TBDML_postload.cmd
!// After load the commands written below will be executed
RESET
done .\cmd\TBDML_postload.cmd
Postload command file correctly executed.
Error: Loading failed!
in>
已经困扰我好久了,我尝试过解锁,能解锁;但每次解完,就显示"unable to connect to target CPU",求大神指点!!!!!!!!!
