MSP-EXP432P401R LaunchPad 开发套件
发布时间:2015-7-6 14:36
MSP-EXP432P401R , LaunchPad
Texas Instruments MSP-EXP432P401R LaunchPad Development Kit enables you to develop high-performance applications that benefit from low power operation. The kit features the MSP432P401R, which includes a 48MHz ARM® Cortex® M4F core, 95uA/MHz active power and 850nA RTC operation, 14-bit 1MSPS differential SAR ADC and AES256 accelerator. This includes an on-board emulator with EnergyTrace+ Technology, which means you can program and debug your projects without the need for additional tools, while also measuring total system energy consumption. All pins of the MSP-EXP432P401R device are fanned out for easy access. These pins make it easy to plug in 20-pin and 40-pin BoosterPacks that add additional functionality like wireless, capacitive touch and more. Features Low-power, high performance MSP432P401R MCU 48MHz 32-bit ARM Cortex M4F with Floating Point Unit and DSP acceleration Power consumption: 95uA/MHz active, and 850nA RTC standby operation Analog: 24Ch 14-bit differential 1MSPS SAR ADC, Two Comparators Digital: Advanced Encryption Standard (AES256) Accelerator, CRC, DMA, HW MPY32 Memory: 256KB Flash, 64KB RAM Timers: 4x16-bit, and 2x32-bit Communication: Up to 4 I2C, 8 SPI, 4 UART 40 pin BoosterPack Connector, and support for 20 pin BoosterPacks On-board XDS-110ET emulator featuring EnergyTrace+ Technology 2 buttons and 2 LEDs for User Interaction Back-channel UART via USB to PC Kit Contents 1 x MSP-EXP432P401R LaunchPad Development Kit 1 x Mini-USB cable 1 x Quick Start Guide User's Guide: Quick Start Guide: View Product Detail |
