有深圳的朋友找工作吗?sagem招聘
发布时间:2009-7-14 23:20
发布者:riverpeak
Firmware Engineer(Printer) Responsibilities: In charge of establish he specification, etablish the detailed Firmware design, write the source code and pass the unit tests and qualification test accordingly to a plan that he will have to prepare under the direct supervision of the team leader Activities 1. Define the design of the firmware module: to identify and propose solutions to prove its necessary design margin. 2. Perform the development (specifications, design, code writing) and the qualification of the firmware module. 3. Define and perform the unit tests the firmware module in the product. 4. Report to his/her superior about the progress of the work, on technical aspects and planning. 5. Suggest refinements for methods and tools. 6. Ensure that technical information is collected, organised, and analysed, propose new ideas, propose projects/products. 7. Identify innovations so that they may be protected and capitalized on by patents. Knowledge and skills: 1. Knowledge about embeded firmware development over at least one famous chipset (Intel, Motorola,..) 2. Knowledge about most popular Fw language,at least C, C++ (best also should be assembler language) and environment development (Visual C++ for example) 3. Knowledge about emulator system for embeded system 4. Knowledge about at least one saverage system tool (able to regenerate old version of a firmware) 5. Mastery of technical English Testing Engineer(CPE) Responsibilities 1. Be Responsible of the quality of the product 2. Define the test scenarios 3. Make test planning 4. Define and setup the test environment 5. Perform the validation of the product 6. Make test reports 7. Participate in product function improvements Requirement 1. 2 years experience with Bachelor degree 2. Good knowledge of communication technologies 3. Excellent knowledge of TCP/IP and related protocols 4. Excellent organization skills 5. Good communications skills 6. Good learning skills and autonomy 7. Analysis skills and rigor are required. 8. Willingness to work in team Validation Engineer Responsibilities and Activities Responsible of the quality of the product Define the test scenarios Write test plan Define and setup the test environment Perform the validation of the product Write reports Participate in product function improvements Knowledge and skills Good knowledge of communication technologies Good knowledge of Wifi protocol/Radio protocol/Ethernet protocol Good knowledge of GPRS application/HTTP application/Gateway application Excellent organization skills Good communications skills Very good english (written and spoken) Good learning skills and autonomy Analysis skills and rigor are required. Willingness to work in team SW Engineer(Printer) Responsibilities 1. In charge of establish he specification, etablish the detailed Firmware design, write the source code and pass the unit tests and qualification test accordingly to a plan that he will have to prepare under the direct supervision of the team leader 2. Define the design of the firmware module: to identify and propose solutions to prove its necessary design margin. 3. Perform the development (specifications, design, code writing) and the qualification of the firmware module. 4. Define and perform the unit tests the firmware module in the product. 5. Report to his/her superior about the progress of the work, on technical aspects and planning. 6. Suggest refinements for methods and tools. 7. Ensure that technical information is collected, organised, and analysed, propose new ideas, propose projects/products. 8. Identify innovations so that they may be protected and capitalized on by patents. Skills 1. Knowledge about embeded firmware development over at least one famous chipset (Connexant, Toshiba, Zoran ,..) 2. Knowledge about most popular Fw language,at least C, C++ (best also should be assembler language) and environment development (Visual C++ for example) 3. Knowledge about emulator system for embeded system 4. Knowledge about at least one saverage system tool (able to regenerate old version of a firmware) 5. Mastery of technical English |
