查看: 5652|回复: 3
Board Viewer 2014下载
发表于 2014-5-7 14:41:56 | 显示全部楼层 |阅读模式
关键词: Board
Features of Board Viewer
  • PCB/Panel/Footprint data can be referred.
  • Display on/off and color of each layer can be specified.
  • The order of the display of each layer can be specified.
  • Visible Layer Group can be configured.
  • Display "Mirror View" is supported.
  • The display color of each signal can be specified.
  • Data can be searched by Signal name, Reference Designator and Terminal in PCB data.
  • Detailed information on data can be referred.
  • The distance between the data can be measured.
  • Distance between two points can be measured using the Ruler tool.
  • Add, delete or move the text comments in Board Viewer.
  • One PCB data file can be referred to from multiple Board Viewers simultaneously.
System Configuration
The following configuration is required.
OS
  • Windows 8.1 Enterprise (32bit/64bit)
  • Windows 8.1 Pro (32bit/64bit)
  • Windows 8.1 (32bit/64bit)
  • Windows 7 Ultimate No SP/SP1(32bit/64bit)
  • Windows 7 Enterprise No SP/SP1(32bit/64bit)
  • Windows 7 Professional No SP/SP1(32bit/64bit)
  • Windows 7 Home Premium No SP/SP1(32bit/64bit)
  • Windows Vista Ultimate SP2 (32bit/64bit)
  • Windows Vista Enterprise SP2 (32bit/64bit)
  • Windows Vista Business SP2 (32bit/64bit)
CPU2GHz or faster
RAM1GB or higher
Virtual memorySystem recommended value
Hard disk39MB free space or more
Display1024 x 768 screen resolution or more,
16bit High Color / 32768 colors or more
Supported revision of board data
Board Designer
  • Rev.16.xxx
  • Rev.15.xxx
  • Rev.14.xxx
  • Rev.13.xxx
  • Rev.12.xxx
  • Rev.11.xxx
  • Rev.10.xxx
  • Rev.9.xxx
  • Rev.8.xxx
  • Rev.7.xxx
Design Force
  • 2014.xxx
  • 2013.xxx
  • 2012.xxx
DFM Center
  • 2014.xxx
  • 2013.xxx
  • 2012.xxx
  • Rev.5.0
  • Rev.4.0
DFM Elements
  • 2012.xxx
DFM Inkjet
  • 2014.xxx
  • 2013.xxx
  • 2012.xxx
  • Rev.1.3
BV2014000-1.zip (37.36 MB, 售价: 5 积分)
 楼主| 发表于 2014-5-7 14:42:28 | 显示全部楼层
发表于 2014-5-8 09:32:36 | 显示全部楼层
下载下来!!!!!!!!我自己好好学习!!!!!!!!!!!!!!!!!!
发表于 2015-1-31 22:13:22 | 显示全部楼层
下载下来看一下
