Banana Pt香蕉派 A20开发板,BananaPI 支持 Android,inux,树莓派,cubieboard
Banana PI M1是为了配合Elastos.org开源OS推广而推出开源硬件平台,BananaPI M1是一款比树莓派更强悍的双核Android4.2产品。BananaPI 支持 Android系统,,Debian linux系统,Ubuntulinux系统, Raspberry Pi 系统and cubieboard 系统.可以作为媒体播放器,智能路由交换器,中继器,工控机,机顶盒,网络播放器,开发板,个人娱乐学习编程软件等。
Elastos将协调多CPU形成基于“软件/硬件服务”的家庭云生态环境。
Banana Pi 外型类似树莓派,但它性能却比树莓派更加强焊,并且可以运行树莓派image.
Banana PI 硬件:硬件基于ARM架构,1Ghz ARM7双核处理器,1GB DDR3内存,千兆以太网口,SATA Socket,流畅运行Android4.2.2。Banana PI M1体积如信用卡大小,轻松运行《雷神之锤三:竞技场》这样的游戏,支持1080P高清视频输出,GPIO兼容Raspberry Pi并直接运行其ROM Image
硬件规格
| | CPU
| A20 ARM Cortex™-A7 Dual-Core
| GPU
| ARM Mali400MP2Complies with OpenGL ES 2.0/1.1
| Memory (SDRAM)
| 1GB DDR3 (shared with GPU)
| Onboard Storage
| SD (Max. 64GB) / MMC card slot UP to 2T on 2.5 SATA disk
| Onboard Network
| 10/100/1000 Ethernet RJ45,optional WIFI
| Video Input
| A CSI input connector allows for the connection of a designed camera module
| Video Outputs
| HDMI, CVBS , LVDS/RGB
| Audio Output
| 3.5 mm Jack and HDMI
| Power Source
| 5 volt via MicroUSB(DC In Only) and/or MicroUSB (OTG)
| USB 2.0 Ports
| 2 (direct from Allwinner A20 chip)
| Buttons
| Reset button: Next to MicroUSB connector
Power button: Next to Reset button
Boot button (Optional): Behind HDMI connector
| GPIO(2X13) pin
| GPIO,UART,I2C bus,SPI bus with two chip selects,
CAN bus,ADC,PWM,+3.3v,+5v,ground.
| LED
| Power Key & RJ45
| Remote
| IR (Optional)
| OS
| Android 4.2,Firefox OS and Linux etc. OS
| Interface definition
| | Product size
| 92 mm × 60mm
| Weight
| 48g
| 硬件示意图:
正面
背面
硬件接口说明:
外设硬件连接示意图
更从信息,请访问Banana Pi的官方网站:www.banana-pi.org www.sinovoip.com.cn
